Block Questions
  • GreenBeast
    • Apr 2011
    • 12
    Block Questions
    Are the block sensers the same between the 3.1 and the 3.4 pushrod engines?
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    are you referring to the 3100 and 3400 or the Fbody 3.1 and 3.4?
    • GreenBeast
      • Apr 2011
      • 12
      I am talking the 3.1 and 3.4 in the Front Wheel Drive Applications. Wbody to be exact
      • Purple pit
        • Oct 2012
        • 718
        Well there is the problem. A early 3.1 is in may ways different than a 3100, so a year is needed. Also 3.4 is what a RWD is called, the 3400 is the FWD. Those two have some different sensors.
        Grand Prix trans with 3.33FDR
        • GreenBeast
          • Apr 2011
          • 12
          okay well fine the 3100 and the3400
          • Purple pit
            • Oct 2012
            • 718
            Not trying to rag on you. It just helps to keep things clear.
            The 3400 swap guide PDF as some info on the sensors.
