Motor question
  • The Hulk!
    • Jun 2007
    • 47
    Motor question
    I'm about to lock down a motor for my van
    I'm wondering is there any differences between my 2003 motor and a Montana 2006 motor?
    Is a 2006 motor different at all? Or does it bolt right in just use my wiring harness?
    Thanks!
    Jordan
    2004 Grand Prix G.T.P T-72 Turbo 28PSI,BS cam.581WHP Sold..
    2009 G8 GT Cam,meth,cutouts,tune,LT's 420.1whp
    2003 Oldsmobile Silhouette Intake,Tune,Built Trans
  • cavalier3400z
    • Jul 2012
    • 29
    2006 is a 3500. I do not think a 3500 was made in 2003 only 3400. Of you have a 3400 most likely you will have to get a trigger wheel and what ever else is needed for a 3500 swap. Some here should be able to help you. 3500 is an amazing engine with tons of potential.
    Sent from my iPad using Tapatalk HD
    • The Hulk!
      • Jun 2007
      • 47
      not interested in 3500's...
      i like being able to just straight swap the motor
      and not have to worry bout extra stuff...
      thanks for answering the question tho i was also under the impression that 2006 3400 dosent exist...
      guys says its a 3400 tho... gonna have to see it i guess
      but any 3400 is direct swap tho right any 97-2005 3400 should use the same wiring harness correct?
      thanks
      Jordan
      • TurboGTU
        • 453
        Look at the crank sensor in the middle of the block not the harmonic balancer. If its two wire your golden. If 3 wires , crank is different.
