42lb Injector clips on 3.4?
  • coolraptor
    • Dec 2013
    • 7
    Hello! Long time lurker, first time poster.
    Aaron A. from marietta ohio.
    Current project is a very mild (5-6psi) remote mount turbo setup on a 2000 Impala 3.4 base.
    (if anyone has a set of turbo manifolds/headers already setup they want to sell, i would be interested, however!) lol the remote mount setup is mainly because iam curious to see if it will work at all and its cheaper than buying headers/manifolds or making my own.
    Dumb question iam sure has been covered before (search didnt seem to work for me?)
    I have a set of Lucas 42lb Injectors, the multec to ev1 adaptors, the injector brackets from Milzy, but I do not have nor know what type of injector clips I could use for these?
    They are the shorter fat injectors vs the tall skinny multecs which iam sure you all know.
    Trying to get everything in order so I can do the injectors, egr, thermostat, and pcm all in one shot one evening here.
    So if anyone knows what clips and/or where to find them, the info would be greatly appreciated!
    After that I can start bolting the turbo stuff & HD trans stuff on and see if it blows up
    P.S.-Also have a set of brand new take-off trailblazer Injectors, but was told they would be too small for 6psi. Any thoughts?
    2000 Chevy Impala, 3500 top Swapped, Overkill Tune, 42lb Injectors, EGR Delete, LS Lifter Springs Mod, TB coolant Bypass, 'warm air intake', 4t65HD Trans Conversion w/ shiftkit, - KYB GR2 Struts, LS1 Fbody brakes, GM Rear STB w/ Done Rome Brackets, Resonator delete & 2.5inch exhaust.
    1995 Chevy Camaro Z28 - 383ci LT1 pt76, 6speed, drag car.
  • Mars
    • Apr 2004
    • 826
    i don't use clips, just toss them in. they are only on there for assembly line purposes. don't use the blazer ones, go 42#.
    • coolraptor
      • Dec 2013
      • 7
      Ok sounds just fine to me, thanks Mars!!!
