Which headers for 3.4L / 3400 / 3500 hybrid?
  • bachert24
    • Jul 2014
    • 73
    I have 3.4 block, 3400 pistons, upper intake,and tb, 3500 heads and lower intake. Will 3.4 headers bolt up or do I need 3500 headers?
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    what car/truck?
    • bachert24
      • Jul 2014
      • 73
      95 Camaro
      • Guest
        With some modifications to the port flange and primary, you use the headers that will fit your vehicle.
        • bachert24
          • Jul 2014
          • 73
          Will the ports and bolts match up to the 3500 heads?
          • Guest
            • carbon
              Procrastinator
              • 388
              Slot dem holes!
              - Ben
              • bachert24
                • Jul 2014
                • 73
                I'll do that, hopefully it's all stuff I can do lol
                • caffeine
                  • Jan 2012
                  • 1489
                  It's easy and obvious what needs to be done when the parts are in habd
                  '86 Fiero, 3500, 4-speed
                    Slotting the holes works for mounting but the typical 1.5" primaries on those 3.4 headers are tiny. Hopefully you can find some that are 1 5/8".
                    If you are fairly close to eastern Iowa I have some proper longtubes that you can test fit.
                    • bachert24
                      • Jul 2014
                      • 73
                      For a 3.4? How much?
                        They were on a 3500 in a 3rd gen Camaro, but with the different K member your car has they might fit. 1 5/8" primaries, 32" long with correct D port flanges and V banded collectors, Ceramic coated.
                        I'd do $450 but we'd have to make sure they'll fit first.
