300 hp N/A carb 2.8 V6 engine
  • veekuusi
    • Aug 2011
    • 205
    #46
    I was thinking of putting the pistons to the block this weekend.
    First you have to check the piston ring caps of course.
    I was taking the rings out of the bag, I found out that there were only 4 rings.
    4 top rings, 4 second groove rings and 4 oil rings.
    I ordered a FULL SET OF NEW RINGS.
    I checked the order, I did not mention that I have a 6 cylinder engine,
    some one has thought I have a 4 cylinder engine.
    I should have cheched the order earlier more carefully.
    Now I have to get 2 sets of rings here asap.
    Maximum one week.
    They are Total Seal rings.
    Lets see what I can do.
    I do not want to put old rings to 2 pistons .
      Damn that sucks! Best of luck getting them. Every thing I touch with my engine is turning into a crazy project as well lol gotta love building a performance 60° v6
      • veekuusi
        • Aug 2011
        • 205
        #48
        I got the missing piston rings today.
        Ben helped me.
        I also got an extra set of rings, for the future.
        • Purple pit
          • Oct 2012
          • 718
          #49
          All the pistons came out to be the same weight? Planning to check the balance of the whole assembly?
          Grand Prix trans with 3.33FDR
          • veekuusi
            • Aug 2011
            • 205
            #50
            2 new pistons came out from Diamond couple of grams heavier than the old 4 ones.
            All the measurement are the same, but they did weight more than the old ones.
            But we took material out of the wrist pins of those 2 pistons to get
            all the pistons and wrist pins and rings to the same weight.
            All the 6 connecting rods weight the same ,tolerantly in 1 gram.
            And the balance of the whole assembly has been checked, it is OK.
            You can see the new piston in the right ,wrist pin has been lightened (to reduse weight).
            • Purple pit
              • Oct 2012
              • 718
              #51
              Cool man, makes me feel better. You know I'm a fan! Hope that wrist pin holds up, looks a bit thin.
                I think he just tapered the end of it and didn't drill it out as it appears. The one on the left also appears to not have a spirol-lox in yet so that is deceiving in appearance.
                • Purple pit
                  • Oct 2012
                  • 718
                  #53
                  Oh yes, I see that now. Thank you. Damn it's been a long time.... wish I could do another build.
                  • veekuusi
                    • Aug 2011
                    • 205
                    #54
                    Cylinder head assembly.
                    ARP rocker arm studs 7/16 bottom and 3/8 top.
                    And 7/16" helicoils.
                    • Guest
                      #55
                      Nice!
                      • Will'sFiero
                        Too many valves
                        • 276
                        #56
                        You might want to look into Time-Serts, as rocker studs are a high load rather than high cycle application. Helicoils tend to pull out on high load apps (e.g. head bolts), Time-Serts tend to unscrew on high cycle apps.
                        Time-Serts install into the same STI-tapped holes as helicoils, so switching isn't a big deal.
                        Current:
                        \'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
                        \'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
                        \'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
                        Gone, mostly forgotten:
                        \'90 Pontiac 6000 SE AWD: slow but invisible
                        • Purple pit
                          • Oct 2012
                          • 718
                          #57
                          Is it me or are those ports a bit on the smooth side?
                          • 34blazer
                            • Sep 2007
                            • 341
                            #58
                            ^^^ I'd profile the intake ports with a carbide. A slightly bent shaft round ferrous carbide works well, on low speed.
                            '86 Grand National
                              Yep, needs more texture. The rough carbide finish is worth decent gains.
                              Like this:
                              Great article, he gained 17RWHP going from 60 grit finish to the above: http://hotrodenginetech.com/pipemax-...-head-porting/
                              • Will'sFiero
                                Too many valves
                                • 276
                                #60
                                Like this:
                                Great Info!
                                Current:
