3900 Max timing degrees
  • farmerz24
    • Feb 2004
    • 361
    Does anyone know roughly what the stock 3900 runs for Max timing at WOT. Just want to get a baseline. Should it be in the 30degrees of timing or is that too much ?
    Also the cam is advanced 15 degrees correct ? Should it be brought back to 0 for optimal top end? Seems as if it is not very quick right now.
    Thanks and let me know
  • caffeine
    • Jan 2012
    • 1489
    Usually advanced cam would be for low end power, retarded for top end. And I typically run 20* of timing on my 3500 at WOT, down to 12* under boost.
    '86 Fiero, 3500, 4-speed
