3.1 Camaro-Firebird flywheel
  • sspeedstreet
    • 282
    Does or did anyone make a steel flywheel for the early 90's F-body 3.1 V6? I can only find stock or stock replacement.
    Neil
  • caffeine
    • Jan 2012
    • 1489
    That's all you'll find. I looked for a while for alternatives. If it makes you feel better I'm putting over 400whp through a stock replacement
    '86 Fiero, 3500, 4-speed
    • sspeedstreet
      • 282
      Pretty much what I've found. I was looking for something better to modify for my 3.4DOHC with an F40 trans. A guy over on Pennocks used a stock F-body flywheel, machined the ring gear flange off and re-mounted the ring using stand-offs to the proper location. Along the way he found it to be pretty out of round in a lot of spots. Something billet would sure be a better starting point.
      • caffeine
        • Jan 2012
        • 1489
        There's an aluminum flywheel for the fwd motors
        • sspeedstreet
          • 282
          There's the stock G6 dual-mass cast iron one and other than that I'm not aware of anything but custom made. There's been talk about a CNC'd billet aluminum one, but it's always a "year away" from delivery. Besides, I have a Fidenza on the car now and I'd like to go back to steel.
          • caffeine
            • Jan 2012
            • 1489
            The fidanza and spec flywheels are the same style afaik
            • caffeine
              • Jan 2012
              • 1489
              BTW I don't think there's enough meat on the 3.1/3.4 RWD flywheels to turn down for a smaller ring gear
              • caffeine
                • Jan 2012
                • 1489
                However, if there's room in the bellhousing, you can run an unmodified RWD flywheel and make a 9 1/16" starter shim. It works fine trust me
                • sspeedstreet
                  • 282
                  It's not a matter of a smaller ring gear; the modification uses the same gear. It needs to be closer to the plane of the crank flange.
                  • caffeine
                    • Jan 2012
                    • 1489
                    Why?
                    • caffeine
                      • Jan 2012
                      • 1489
                      The ring gear distance from crank flange is the same as the FWD flywheels
                      • caffeine
                        • Jan 2012
                        • 1489
                        • sspeedstreet
                          • 282
                          True, but apparently there is a difference between the Camaro and the Fiero ring gear and it has to be changed over. By the time the seat is cut down for the new gear it was pretty thin. So he just cut it all away and used the stand-offs instead.
                          • caffeine
                            • Jan 2012
                            • 1489
                            I told you the difference. The camaro/rwd flywheel has a larger diameter ring gear. As long as it fits in the bellhousing you can simply use the rwd ring gear with a 9 1/16" starter shim.
                            • geoffinbc
                              Iron Head Enthusiast
                              • 5831
                              He means 9/16" shim not 9 and 1/16" like it is written. But I have to agree with keeping it simple rather than spacing the ring gear off the flywheel.
