Crane 272 camaro 3.4????
  • Guest
    Hello, please i need help.
    Anyone knows if the crane cams 272 fits into a 95 camaro 3.4?, this due sfi cam has a sensor lobe (or tab).
    I know 272 is a big cam but im modding a spare engine with 3500 head swap, the only thing i need to know is if 272 has the sensor tab/lobe.
    Thanks....
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Better call COMP to confirm.
    • Hard Driver
      • Aug 2010
      • 77
      Thanks....
      I had the Crane 272 in a 2.8 but can't rember if it was designated for the 3.4 or not,as I recall it had a .427 / .454 lift and it isn't that big it has a mild idle.
      • Hard Driver
        • Aug 2010
        • 77
        I think I made a mistake that lift was for a 260 crane cam.
          the 272 has a pretty mean lope.
          The one I've seen did not have the stuff for SFI. You could still use it though, might set a code but the engine should still run.
          • caffeine
            • Jan 2012
            • 1489
            Ditto just re-flash the PCM to delete the cam sensor code if its not SFI compatible.
            '86 Fiero, 3500, 4-speed
            • BillS
              • Oct 2005
              • 132
              I don't think any of the Crane 272s have the lobe; mine certainly didn't.
              Just reprogram to delete the SFI.
              • caffeine
                • Jan 2012
                • 1489
                Actually according to Alldata, SFI will still be used if there is a 24x sensor present and working. It will just be less accurate apparently.
