Composite head gasket VS multi layer steel for boo
  • tubov6cav
    • Mar 2014
    • 63
    So I recently got head gaskets for my 3.4/3.5 hybrid. These gaskets are a composite type and I have read a few things about these gaskets not holding up under boost. Granted I'll only be running 15lbs at most. So what I'm wondering is what would you guys suggest for my application?
  • Heartbeat1991
    • Mar 2013
    • 68
    I just got Cometic MLS gaskets for mine. I didn't want to bother with tearing it back down again if the Fel-Pro fails.
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      I'm running 3500 graphite gaskets, they're supposedly tough as nails.
      • tubov6cav
        • Mar 2014
        • 63
        Any experiences?
        • ericjon262
          build it.
          • Jan 2010
          • 2218
          well, no failures yet if that's what you mean... but the car hasn't been run long either.
          • tubov6cav
            • Mar 2014
            • 63
            Oh ok!
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              IIRC, Mars went 11.13 in his Camaro on them...
              • tubov6cav
                • Mar 2014
                • 63
                Ok, I'm fine with using them if they work. I got them for a great price that's why I have them. I usually use cometic.
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  the gaskets you have pictured above are not the graphites. the graphites are a GM part, not felpro.
                  • tubov6cav
                    • Mar 2014
                    • 63
                    Oh ok I see where you said that now. Haha sorry
                    • caffeine
                      • Jan 2012
                      • 1489
                      Stock 3500 graphite gaskets are good to a little over 11psi with stock head bolts. Will probably hold more with head studs. When I ran 14 psi I blew both head gaskets after a few months of driving.
                      '86 Fiero, 3500, 4-speed
                      • tubov6cav
                        • Mar 2014
                        • 63
                        Ok then I should probably go with the MLS.
                        • caffeine
                          • Jan 2012
                          • 1489
                          You're supposed to have the block and heads resurfaced finer than stock if you go MLS.
                          • tubov6cav
                            • Mar 2014
                            • 63
                            Yeah I know, they will be.
                            • dskopek
                              • Jul 2009
                              • 124
                              I am running the MLS gaskets from Ben in my 3.4 at 16 lbs boost, no problems so far
