injector for turbo 3100
  • jman093
    • Jul 2008
    • 164
    I'm in the process of top swapping one of my TGP's to large port 3100 heads and intakes and 56mm 3400 throttle body. I got all the parts dirt cheap a couple weekends ago, just need some time and warm weather to make it all work.
    I'm curious as to opinions on whether I should run the 22.5# LG8 injectors which would keep flow rate identical to the stock LG5, or run a set of 28# Atlas 4.2 injectors that I have laying around. I'll probably send out one of the sets for rebuilding/flow-matching.
    On one hand, a top swap doesn't seem like a huge upgrade necessitating larger injectors, but at the same time I'd be running stock injectors on what has essentially become a turbocharged LG8, and turbocharging generally would necessitate larger injectors.
    Jesse M.
    3x 1990 Turbo Grand Prix
    1987 Monte Carlo SS Aerocoupe
  • caffeine
    • Jan 2012
    • 1489
    I would definitely go with larger injectors. Your limiting factor is probably gonna be the turbo at this point though.
    '86 Fiero, 3500, 4-speed
      i would say depending how heavily you want to breathe on it, the stock L67 injectors might not be a bad route.
      • jman093
        • Jul 2008
        • 164
        I'm now leaning toward running the larger ones as well. Definitely don't need 36 pounders though. For the foreseeable future, the T25 is remaining.
        Jesse M.
