Roller ip rocker for M10 Heads
  • TazMan
    • Jun 2006
    • 285
    Hi everyone. I have a 2001 Lumina that I'm making a few upgrades to. Are there any 10mm roller tip rockers for these heads? I read somewhere on the forum that they make conversion studs to use the 8mm full roller tips on the 10mm heads. Does anyone know where I can get them?
  • ericjon262
    build it.
    • Jan 2010
    • 2218
    I'm not aware of any full roller rockers out there for these engines. Summit does sell screw in studs that can bolt into our heads, but is there a compatible rocker... who knows.
    • Heartbeat1991
      • Mar 2013
      • 68
      Nothing full roller was stock. I put Crane full rollers on mine, but I used different heads.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        You can buy conversion studs for M8 or M10 threaded holes. These will allow you to run Narrow Body Full Roller rockers on your engine. The Crane rockers require LIM clearancing other brands may not. If your not looking for this much work then stick with the stock roller fulcrum rockers.
