Has anyone run a nitros plate ??
  • shrike
    • Apr 2015
    • 29
    Has anyone run a nitrous plate on a 3.4 ?
    I am considering a 100 shot on my 3.4 build.
    I am wondering if it will stay together.
    Thanks...
  • Guest
    if tuned correctly it will stay togethor. Ran a 100 shot on mine on top of a turbo. I started with a 35 and worked my way up dialing it in and watching the a/f ratio
    • shrike
      • Apr 2015
      • 29
      Yikes ! a turbo... On a stock rotating assembly? Did you use a forged rotating assembly ?
      Thanks...
      • carbon
        Procrastinator
        • 388
        Thanks...
        - Ben
        • Guest
          Thanks...
          stock rotating assembly other than hyper .030 over pistons. I bought the motor already rebuilt from another member with 30k miles on it.
          • shrike
            • Apr 2015
            • 29
            Wow, cool... I feel better about a little juice now. OK thanks !
              Make sure to get a set of plug that are a step cooler and run the Copper core, Or Iridium plugs. I just fried a set of double platinum's which I think were also in the wrong heat range.
              • shrike
                • Apr 2015
                • 29
                I guess I will start thinking about... I have a 95 Camaro motor/tranny going into a small british car w/four barrel, some cam, compression and roller when possible.... I think it would surprise a few people if I help it along w/a 100 shot. I don't want to hurt the motor though... I'm just getting the tranny back tomorrow and then i will start on the motor...
                Thanks for lending your advice you guys !...
