3.4 with a distributor ?
  • opel_inside
    • Jun 2016
    • 22
    Does the 3.4 block have the provisions to run a distributor ?
    If i put an older intake on it can it use a dist ?
    Or did they remove that setup cuz they went DIS ?
    Or can I only run a distributor on a 2.8 block ?
  • neophile_17
    • Jun 2004
    • 306
    The 3.4L and even later motors have a plug that runs the oil pump. You can replace the plug with a distributor as long as it clear your intake. Fiero guys use their stock intake and distributor with a 3.4L all the time.
