2.8 + Gen III head questions...
  • e3pres
    • Aug 2004
    • 8
    Hey guys,
    I recently bought a set of Gen III aluminum heads. (Casting Number 24503769) I want to use these on a 2.8 RWD engine. From everything that I've read, the heads should work... I hope. Has anyone here done a similar swap? Also, this engine will be in a race truck, so I'd like to run very high compression (11.5-12.5:1). Does anyone make an off-the-shelf piston for a 2.8 that will give that kind of compression with Gen III heads and a long duration cam?
    TIA,
    Adam
  • RacerX11
    • 1060
    With regular, stock low-output 2.8 iron head pistons, and a 0.060" thick gen2 head gasket, the gen3 heads will get you ~11.7CR, and with the high-output 2.8 pistons, you will get ~12.5 CR. By playing aorund with combustion chamber porting or thinner head gaskets, you should be able to get the desired compression.
    Marty
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
    • v6h.o.
      • 1418
      just making sure but... you do know you also need GEN 3 intake manifolds.
      but then again with this being a race truck you might have a custom manifold in the works already.
      Colin
      • Guest
        Check out my www button. I have a turbo hybrid in my '85 Jimmy. If you have any questions, just ask.
        • e3pres
          • Aug 2004
          • 8
          Thanks for the quick replies. Will the Edelbrock 4bbl intake not work on the Gen III heads? I was kinda expecting having to fab one from scratch in order to run a carburetor, but I was keeping my fingers crossed that I could find a bolt-on.
          Will the 0.060" thick head gasket take care of any valve interference that a long duration cam may cause? The Chevrolet Power book says that the canted valves will not clear the old style pistons.
          Thanks again for the quick replies!
          --Adam
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            No the Eddi manifold will not wor on GenIII or Gen II heads.
            Canted valves will not be a problem. I dont know why the book would state that unless they are talking about a VERY high lift cam.
