Wanting to upgrade my intake to 00+. I need an EGR adapter.
  • EspanolaGuitarista
    Visionary
    • Feb 2004
    • 254
    Who do I talk to?
    How much does it cost?
    Is it available?
    My intake gaskets are brand new. Can I reuse them?
    I want the 62mm TB. This has been debated many times. So should I just try it and see if it works?
    Port or extrude hone? I think it can be ported successfully when I took it off and looked at it.
    Port match the intake/heads or leave it alone?
    Injectors, upgrade or stay the same?
    The heads looked great. I see no need to port them. Just use a higher lift cam.
    Tell me what you guys think.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Lloyd and I can make you that EGR plate and the needed accessories. The last guy we made one for bought it and hte reportedly ditched the idea and just blocked the hole off. So maybe you could buy it off of him.
    In the mean time check this out
    There is more to the system than just a plate. We will make you a special fitting that will adapt the threads in the new manifold to the threads in the old EGR tube (which you of course use again) We will also send you the correct 90* elbow that you will need along with all the correct bolts to finish the job.
      Visionary
      • Feb 2004
      • 254
      Thanks for the info.
      I'll look him up. I have to pass Cali smog. No way around it.
