ET times for 2.8 swaped in 3400SFI
  • Berettaspeed
    • Apr 2004
    • 109
    GRRRRR in a good way and a bad way. you know im trying to get a base time and i keep beating my old time. well here is what i ran with. my 205/60/R15 dunlop sportA2. 40psi in front and rear. I have been working on my launch alot. Full interior some stuff in the car but not more than 20lbs. i weigh about 140lbs.O.E front springs and struts with 155,000 miles on trans. i have a 3400 out of an 03 impala that had 24,000 miles on the motor. plus it was pretty chilly out side that night
    1st run which was the best of the night
    8:41pm-------------------9:08pm
    RT.123-------------------RT -.018
    60ft 2.152----------------60ft 2.308
    330 6.086-----------------330 6.284
    1/8 9.353 @76.04---------1/8 9.554 @75.85
    1000 12.181--------------1000 12.382
    1/4 14.598@93.27MPH----14.800@93.15MPH
    9:13pm-------------------9:27pm
    RT .152-------------------RT.382
    60ft 2.216----------------60ft 2.209
    330 6.195-----------------330 6.154
    1/8 9.498 @75.53---------1/8 9.414 @76.16
    1000 12.356--------------1000 12.230
    1/4 14.786@93.00MPH-----1/4 14.650@93.16MPH
    9:46pm-------------------9:52pm
    RT .211-------------------RT.073
    60ft 2.199----------------60ft 2.197
    330 6.200----------------330 6.196
    1/8 9.481 @ 75.75--------1/8 9.460 @75.65
    1000 12.406--------------1000 12.403
    1/4 14.962@88.42--------1/4 15.267@76mph
    I missed 4th gear ---------i missed 4th again but this time i -----------------------------just coasted down the track
    i raced a VR4 he ran, well if you want to call it a race
    RT.336
    60ft 1.684
    330 4.859
    1/8 7.541 @92.79mph
    1000 9.780
    1/4 11.67@121.93MPH
    89 BerettaGT 3400 5spd
    60' 2.106 street tires
    Best ET 14.313@95.37 N/A
    Now Boosted
    14s@109 (poor tune still rich, poor driving skills, poor owner)
  • 1QUICKHATCH
    • 387
    wow those are some good times!
    14.96@91.47 in the 1/4
    9.63@74.36 in the 1/8th
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Um which times are yours?
      Right - Right and then Left
      • 1QUICKHATCH
        • 387
        what are you running for exaust?
        • Anonymous
          That's odd needing 4th for a 93mph trap speed. What speed are you redlining 3rd at?
          • Berettaspeed
            • Apr 2004
            • 109
            Well my 3rd gear maxes out around 83mph at 6000rpm. I shift alittle early(around 5750rpms) seems to help out a bit. All these are my times except the 11sec one. i just posted them like that so you won't have to scroll down alot. to me it seems easier to read. For an exhaust i don't have anything special. i just took off my muffler.and i used the 3400 rear manifold. otherthan that i still have a cat and its all 2" piping.
            I also decided to try something and run the car with NO EXHAUST. i took off my cat and left the down pipe on the car. about 3ft of pipe total. I went on tuesday. the air was a little muggy but not too bad. track was kinda sticky but could have been better. i just wanted to see if my car would lose power or gain some. well ALOT of people told me no you need back pressure and you car will run slower and like crap. well here was my best time for that night. it did not beat my best overall time but pretty damn close, and with a higher trap speed. So much for the "backpressure" i needed. i figured with 3ft of pipe should have enough backpressure to run.
            60ft 2.219
            330 6.180
            1/8 9.450
            1000 was not working
            1/4 14.623@94.62MPH
            thats more than 1MPH faster than my last best MPH. So i had to have gained HP. before i was in lower 93mph now well in 94mph. this is my 2nd best time ever. my low end needed some work but overall it was a .025 difference between my best. I think its fair to say i gain HP, but i wonder how much?
            Now Boosted
            • Anonymous
              Those gears are even closer than that of the 284s. Well about the same I guess...
              I redline 3rd at an indicated 95, and since I was crossing the line right at 92-93mph at 6800 in 3rd, sounds about right. I am DREADING taking the car to sea level, cuz I will need to go into 4th, but only for a very short amount of time. That is why I am not anticipating a very great time. However after the intake, the car shoud really drop once it has a chance to develop 4th.
              • dykz34
                • Jan 2004
                • 793
                What size tires do you have? You should be able to run 3rd gear to 100mph...
                • Anonymous
                  No I can't get it past 95, INDICATED on my speedo. So that could be off. But I am crossing the lines right near redline in 3rd, and that was about 93.
                  My tires are stock, 235 stock profile.(cant remember the other numbers)
                  • dykz34
                    • Jan 2004
                    • 793
                    If you calculate it out, the Getrag 284 at 7000 rpm should yield you 102.3 mph.
                    Yours might be off a bit because stock tire size is 225/60-16... not 235/xx-16 like you are running.
                    • Anonymous
                      That is weird. Maybe my tach is high, like 6800 really is 6500. But my car is limited at 7150, and that is right where it cuts me off, my tach is just past 7 when it does. So who knows.
                      • 88jbody
                        • Aug 2004
                        • 30
                        I think 40psi is a bit high for your tires...I'd try dropping it down for a couple runs say 30-32 and see.
                        • quantum110
                          • 175
                          Yeah I would say even lower than that, maybe 28-25psi, you shouldn't even be running 40psi on the street...
                          67 Olds Cutlass 2bbl 330 w/ 2 speed Jetaway
                          • Mars
                            • Apr 2004
                            • 826
                            Yeah, them Dunlop tires aren't too bad eh? (for cheap tires) I have the same in a 225/50-16.
                            Last time I was out I ran :
                            R/T ... .562
                            60' ... 2.286
                            330 ... 6.364
                            1/8 ... 9.631
                            MPH ... 75.62
                            1/4 ... 14.73
                            MPH ... 98.04
                            R/T ... .958
                            60' ... 2.418
                            330 ... 6.551
                            1/8 ... 9.825
                            MPH ... XXX
                            1/4 ... 14.920
                            MPH ... 96.14
                            R/T ... .756
                            60' ... 2.421
                            330 ... 6.395
                            1/8 ... 9.639
                            MPH ... 76.52
                            1/4 ... 14.738
                            MPH ... 95.97
                            R/T ... 1.029
                            60' ... 2.343
                            330 ... 6.398
                            1/8 ... 9.682
                            MPH ... 76.18
                            1/4 ... 14.766
                            MPH ... 98.69
                            R/T ... .760
                            60' ... 2.501
                            330 ... 6.533
                            1/8 ... 9.763
                            MPH ... 77.33
                            1/4 ... 14.821
                            MPH ... 96.79
                            R/T ... .524
                            60' ... 2.239
                            330 ... 6.270
                            1/8 ... 9.534
                            MPH ... 75.98
                            1/4 ... 14.593
                            MPH ... 98.05
                            My 60' times are hurting... I know what the problem is though. DO NOT install a 225 series tire on a 16X6.5" rim. I am getting a wierd wear pattern on them... Oh well.
                            Also, my OEM rear shocks are not cutting it anymore, lol, I will have my KYB Gas-a-just's on Wednesday
                            But If I could get my 1/8 times in the 9.4 range, I would be dooing alot better.
                            These times were ran while the car has 14.9* of Knock Retard at high RPM... I can't figure out why it has it, I even tried 105 Octane fuel, still has the knock...
                            • quantum110
                              • 175
                              6.5" is well within the recomended wheel width of a 225/50/16. The total spread is 6-8".
                              Center wear- Over Inflation
                              Both Sholders worn- Under Inflation or Hard Cornering
                              Cupping- Unbalance Tires, Worn Bearings, loose stearing parts, worn or weak spings/shocks/struts
                              Feathering- Indicates a Toe problem
                              One sholder worn- Indicates a Camber Problem
