Exhaust for 3.1
  • Darkhorses
    • 13
    Exhaust for 3.1
    I want to put a new muffler on my 93 Lumina Euro 3.1. Does anybody have any recomendations? This is a daily driver, so I don't want anything really loud, but a nice growl would be great.
    BTW, someday down the road I plan on a new cam,heads, etc. Does anyone know of any good books on rebuilding or modify the 3.1? I'd like to read up before I get started. Thanks in advance.
  • Juglenaut
    • 1130
    If you want just a bark and growl then I would use Flowmaster.
    I am back
    Mechanical/Service Technican
    • skeeterone2
      • Jan 2004
      • 115
      my advice to you would be to get a hanes book and see if that satisfies you... and if not this site has oodles of info on it you just need to look for it... for your exaust question... i would go with flowmasters... i have a dual glasspack setup and its laud... but it gives a very quality sound... people think i have flowmasters untill they look under my car... i would keep the original pipe diameter if your worried about loosing backpressure and for god sake change the cat.
      91\' Mazda miata.
      92\' Lumina (sold)
      • Darkhorses
        • 13
        Flowmaster
        Ok, I got a flowmaster 40 Series Stainless Deltaflow ($40 on Ebay) and put it on the car. The exhaust sounds pretty good (maybe a bit to mellow), but it resonates terribly inside the car. It's actually louder inside the car than outside. Is there any way to fix this? I tried lining the floor of the trunk with sound insulation, but it didn't really change. I don't mind the noise around town, but when I set the cruise it really gets to rattling my ears, especially on a long trip. BTW the car has more get up and go then ever.
        • sharkey
          • Jun 2004
          • 2061
          a buddy of mine has a flowmaster 40 series with resonator tips, and it sounds nice. if you want a real deep sound, get a 60 series. its designed specificly for small displacment motors (were a 40 series is more for v and sounds ausome with our motors
          • mfewtrail
            ~600hp worth of 3.1's
            • 170
            Re: Flowmaster
            A "resonator" will cut down on the drone/resonance in the interior of the vehicle. Type in something like "universal exhaust resonator" on a search engine if you plan on finding one online. Most local exhaust shops should have resonators in stock though. I believe the general rule of thumb is that the longer the resonator, the more sound/resonance it will cancel out.
            Matt F.
            TGP 1/4 mile times
            http://photobucket.com/albums/y33/mfewtrail/
            1990 TGP Coupe VIN Database
            • Darkhorses
              • 13
              I found a place that sells stainless resonators. Does it matter if the resonator is before the muffler or after it? Also, if I replaced the stock 2" pipe with 2 1/2" would this mess up the back pressure? Does the engine computer adjust for this or would I have to make other changes? I'm aiming to eventually have all stainless pipes under the car and would like to run all 2 1/2" pipes if possible.
              • TheProfessor
                • 869
                2 1/2 inch is prime for a 3.1
                and dynomax ultraflow although a bit more costly than flowmaster
                is what i would suggest
                now on to the building part
                start out by reading chevrolet power
                and you know just ask around
                i could offer some suggestions
                what exactly do you want to accomplish with your build is the biggest question
                I Like V660s
                Does Chevy make beer
                ~Jayme~
                • 873.1
                  4L60e slayer
                  • Jun 2004
                  • 83
                  i have a new(not high flow) cat and a delta 40 flowmaster with a dual tip. from idle up to 3 grand it sounds good. (and i dont like the way 6's sound, so that means a lot coming from me).
                  it you want clips IM me.
                  \m/ Carlton \m/
                  99 formula cam only 6.0, 440rwhp, 4500 stall, dana 60
                  03 silverado hd
