For you guys running your engines up to 6500-7000rpm, what sort of changes have you made to your valvetrain? I know some of you guys have the LS1/LS6 springs swap, but is there anything else?
High revvers
Re: High revvers
I had a comp custom grind cam & comp springs & high compression, and it ran to 7k fine,and made power all the way to it aswellOriginally posted by BlinkyFor you guys running your engines up to 6500-7000rpm, what sort of changes have you made to your valvetrain? I know some of you guys have the LS1/LS6 springs swap, but is there anything else?
the mod list from when I got the car
1995 camaro 3.4 5-speed
Hey Wolf! Have you dyno'd your 3.4? I'd like to know what sort of figures that setup would get you. (Sounds sweet)
I have a Crane cams 2-272-h cam with cranes 1.6 RR's on the intakes and 1.5's on the exhausts. duration @ .050 is 216*/228* with .481''/.480'' of total lift (rockers acounted for).
I have Titanium 1.25'' retainers, forged 7 degree locks kmotion K-700 springs.
I only want to turn it 6500 at the most I think.
I have pictures.Seth
Camaro 1
85\' 3.4L, T-5, 3.42gears
Mods at work on,
car domain site 03/13 Saab intercooler flow numbers.
85\' IROC Z28 Ttop 5.0L, auto mostly stock.
how do you like your crane 272
what compression are you runningI Like V660s
Does Chevy make beer
~Jayme~
I have a completely stock bottom end, stock compression, etc.... Crane H-260 Cam/Lifters, .427/210 Intake, .454/216 Exhaust, stock pushrods, stock rocker arms, Rebuilt 3100 heads with valve job. I turn mine to my 6200rpm limiter, but it still wants to pull at that point, so I want to raise the limiter to 6500. I'm probably going to get some better valvesprings before I do so, I also have some Comp Cams 1.6 roller tip rockers in my garage that I will be putting in (bringing lift up to .455" Intake and .484" Exhaust) in the very near future.
Shawn90 Grand Prix STE 3.1 Intercooled Turbo-3100 Hybrid
99 Grand Prix GT
I don't have a block yet, I am waiting so when I go back to the states I can get the engine with the full 3yr warrantie and not waste a year or more from it just sitting.
I will run about a 8.8:1 to 8.9:1 because of the volume added to my chambers. And it's going to be an FI engine.Seth
Camaro 1
Mods at work on,
I have 1.6 rockers for the intakes and 1.5 for the exhasuts also.Seth
Camaro 1
Mods at work on,
What is the benefit of having 1.6:1 roller rockers for the intake, and 1.52:1 roller rockers for the exhaust?
Wouldn't you want 1.52 or 1.6 for all of them? Why would you mis-match the set?
I'm not downing it, just trying to understand. I'm wondering if that's something I should do?
I'm trying to improve mid to upper RPM power in my 3.2 (V6/60 with 3.1 crank / rods in a 2.8 with .040 overbore pistons). I am using a stock 2.8 Fiero Intake manifold.. ported with the throttle body 47 up to 52mm and I've smoothed out the side and tried to enlarge the inside as best as I could.
I'm also considering using the H272 cam. Or the 260.. not sure which yet.
Thanks!!Todd,
2002 Ford Crown Victoria LX
1997 Pontiac GrandAm GT
1987 Pontiac Fiero SE / V6 5-Speed
1987 Pontiac Fiero SE / V6 Auto
1984 Pontiac Fiero 2m4 SE WS6
1981 Pontiac TransAm WS6
1973 Volkswagen Type-2 Transporter
youd be suprisedOriginally posted by 82-T/A [Work]What is the benefit of having 1.6:1 roller rockers for the intake, and 1.52:1 roller rockers for the exhaust?
there are even SBC build combinations where it is better to have different ratio rockers on different cylinders
odd as it might seemI Like V660s
~Jayme~
