Headers????
  • TheProfessor
    • 869
    Headers????
    i know there have been threads on this but i could not find any with the answers to my questions
    does anyone have headers on a v6 L or J body
    anyone know it the S&S 3400 ones will fit in the engine bay
    I Like V660s
    Does Chevy make beer
    ~Jayme~
  • v6h.o.
    • 1418
    i have my own custom made headers in my Jbody...
    the S&S do NOT fit in the jbody engine bay. i have tried. they also dont fit around the transmission either.
    i have pics of the headers and why they dont fit:
    front header hits the 5spd due to the Taller bellhousing of the 5spd compared to the Auto 4T45E in the 3400 Nbody.
    Due to the Trans issue the front header wont even properly bolt up to the head at all.
    due to this front problem... well the whole header would have to be cut refabricated, and welded, and then you'd have to do a new X-over pipe to join the two headers back together)
    Top view.
    Picture Curtousy of BRAD showing how the rear header needs to be re-worked due to its routing is completely wrong, -Lbody manifold/piping going fairly straight down to clear the firewall, the S&S header going angled/diagonal out. the Jbody LBody's basically shared the same Exhaust layout.. very very similiar.
    Colin
      • 9190
      No, they won't fit the bay. Colin tried on a J-body and I tried on an L-body. Here is a pic showing just how off it is...
      Stock downpipe on the bottom and S&S headers on the top.
        • 9190
        Damn you Colin!!!
        • v6h.o.
          • 1418
          Originally posted by bszopi
          Damn you Colin!!!
          muuahahahahaahaaa... too slow :P
          Colin
          • EspanolaGuitarista
            Visionary
            • Feb 2004
            • 254
            Do they need to be made that way?
            Those primaries aren't even close to being equal length!
            • ikessky
              • 614
              So, what about on a newer W-body. Say a '01?? I haven't really poked around the engine bay too much to see if they would fit or not.
              • v6h.o.
                • 1418
                these are the custom made headers i built myself for my V6 5spd jbody:
                REAR:
                FRONT (goes under pan/transmission):
                Colin
                  • 9190
                  Re: Do they need to be made that way?
                  True... but, they are much better than the stock manifolds. Amazingly, I still have yet to see anyone dyno a set of the S&S, but the TOG's are almost exactly the same and they showed a ~17hp gain.
                  • 88jbody
                    • Aug 2004
                    • 30
                    17 HP! where can I get a set? for my jbody? I am currently building a 3400 and a set of headers would comkplement it great.
                    • 88jbody
                      • Aug 2004
                      • 30
                      headers that will fit!
                      • Anonymous
                        Originally posted by 88jbody
                        http://www.jbodyperformance.com/660headers.html
                        Those actually look fairly decent too. However they could use a slightly longer collector, and mor eimportant, longer primaries.
                        How much is 1799 in normal people money?
                        • 88jbody
                          • Aug 2004
                          • 30
                          1799 canadian is About 1100 or 1200 USD, longer collector would be nice but these fit the way the should and are 200% better than stock manifolds
                          • sharkey
                            • Jun 2004
                            • 2061
                            there is no doubt about it, they are 200% better that stock, and they are real purdy, but i think they can be improved apon. i still havent figured out why they need to be made of medical grade stainless steel. a regular stainless or even mild steel would be just fine, and wont rust if its coated
                            i personaly dont like how they still go over the tranny, its the worst possible design ever for underhood temps, especialy with your throttle body right next to the pipe. i am going to be building my own headers, and they will be very close to colin's deign. im going under the oilpan with the front header, but im going to use oval pipe (its like 7/8-1" tall, but wider so it flows the same) for extra ground clearance. im also going to go with about a 10" collector. i will be backing it with dual 2" exaust dumping out the sides.
                            ill be building these once my new motor is ready to go in the car. ill build the headers on the old motor, and once they are finnished, ill send them for coating and put the new motor in, then stick them on.
                            • TheProfessor
                              • 869
                              How much is 1799 in normal people money?[/quote]
                              i think it like 2 kidneys and a foot
                              I Like V660s
                              ~Jayme~
