3400 top end swap for 3.1
  • TheProfessor
    • 869
    does anyone have any usefull info on this
    what will i need
    i am guessing 3400 tb, upper and lower intake, heads,
    do i also need the injectors, rail, and regulator,
    and what about the egr and pcv
    another thing i wondered about is the wiring compatability for the injectors
    i have a 93 beretta gt by the way
    I Like V660s
    Does Chevy make beer
    ~Jayme~
  • v6h.o.
    • 1418
    get the heads, intakes, exhaust manifolds, crossover pipe for exh. downpipe flange for exh.
    Power steering pump for a 3X00, front timing cover (due to p/s flange)
    throttle body, fuel rail,
    coolant pipes,
    ect, ect.
    run the engine off the original 3.1L computer, use the stock 3.1L wiring harness for the injectors, your best off running the 3.1L injectors as well, i run my engine the exact way, on 45PSI fuel pressure, i still have enough fuel to run properly, i dyno'd my car this summer while at 60PSI fuel pressure and i was running 9:1 A/F ratio...
    the way i did my egr, is i just have the electrical connector plugged into the EGR, and not connected to the engine, i dont have emissions testing where i live, so i didnt bother with the headache of trying to modify the egr to work... bah.
    basically just swap the whole top off one engine onto yours. fairly easy to do.
    get all the brackets for things such as throttle body, map sensor, ect ect. you'll need a beretta throttle cable from a 3100 engine as well to work with the new throttle body.
    your lucky as the 3100 came in the Lbodies, so things like coolant hoses and other things came made to fit your engine bay.
    Colin
    • Cliff8928
      • 532
      Re: 3400 top end swap for 3.1
      what will i need
      Is it an automatic?
      Cliff Scott
      89 BerettaGT
      89 Volvo740
      Cliff Scott
      89 BerettaGT
      04 AleroGX
      • TheProfessor
        • 869
        yes automatic
        I Like V660s
        ~Jayme~
        • v6h.o.
          • 1418
          your going to have issues with making sure you have a t.v. or kickdown cable for the auto trans.
          i dont think any 3100 came with a non electronic shift trans. you'll need to custom fabricate a braket piece for the auto trans cable, and use a throttle body that has an attachment point.
          anyone remember if the early 94-95 3100 equiped cars had non electric shift trans? with a kickdown cable?? i cant remember if they did or not.
          im thinking of the old early cutlas ciera style cars and whatnot, as im wondering if they used that setup.
          Colin
          • 3100 MPFI
            • 1522
            you have to find a certain type of throttle body that has the arm for it, and you have to find a bracket that has the opening for the cable. You can use the stock kickdown cable if you just cut the end off, and get a special kit that allows you to attach teh cable to the arm. If you already have the right bracket, adn throttle body, then the total cost of it all is just $10.00 (the price of the kit that has the end that is needed to attach the cable to the throttle body).
            I did it to my car, and it worked fine. I now have the 4T60-E tranny in my car because I blew up the 440-T4.
            Taylor
            1998 Lincoln Mark VIII
            • TheProfessor
              • 869
              so has anyone actually done what i am going to attempt or is this all speculation
              I Like V660s
              ~Jayme~
              • Cliff8928
                • 532
                Well, you can use a throttle junction box from a quad4 auotmaic car (pre-92) in order to route your kickdown cable, I've done it twice so far for people...
                this is the box you would need to do this (my friend mike holding it)
                this is how it fits under the hood ---
                this is what you have to modify on the throttle body bracket...
                The 1994 3100 throttlebodies do have a provision for a 3rd cable, but I've never seen a car which used it...
                Cliff Scott
                89 BerettaGT
                89 Volvo740
                Cliff Scott
                89 BerettaGT
                04 AleroGX
                • Anonymous
                  Would there be any difference between a 2.8 3400 top end swap vs. 3.1 top end swap? There has got to be some sort of difference.. at least in the power section.
                  • TheProfessor
                    • 869
                    a 2.8 is the same as a 3.1 with a different crank resulting in a smaller stroke
                    also different pistons resulting in a 8.9 compression ratio
                    you would not gain as much on a 2.8 with a top end swap but if you wanted to get you 2.8 rebuilt into a 3.1
                    I Like V660s
                    ~Jayme~
                    • geoffinbc
                      Iron Head Enthusiast
                      • 5831
                      Me and my friend might do this swap. He has Crane Gold Race roller rockers and Crane valve springs can he keep them?
                      • 98goldZ
                        unfinished projects
                        • Nov 2009
                        • 20
                        hey guys, i have alot of these parts if someone is interested. i have complete 01 3400 heads with rockers and valve covers, upper and lower intake, timing cover. sorry i junked the exhuast manifolds yesterday. all this came off of my sisters good running 01 van that she let get low on oil and spun a rod. i also have a throttle body and bracket off the 04 grand am donor motor. im looking to see what this stuff is worth so i can make some one a good deal on it. let me know if you are interested in any of it.
                        thanks,
                        matt moon
                        • carbon
                          Procrastinator
                          • 388
                          And Matt Moon receives the Bottom of the Barrell award for digging up a six year old thread...
                          - Ben
                          • 98goldZ
                            unfinished projects
                            • Nov 2009
                            • 20
                            lol WOW. i FAIL. haha. i done a search and this was near the top. im usally good to look at post dates, as to not do such a thing. i must have just looked at the month and day and ASSumed it was this year since it was near the top of my search. oh well. ive done worse things in my life i guess.
