Reversing the Upper Plenum on a 2001 3400?
  • Quintin66
    • Aug 2004
    • 56
    From the looks of Pics I've seen, the upper plenum on the '99 and up 3400 would bolt on backwards. has anyone tried this before. I dropped the DOHC plans, and am after a 3400 for my spitfire. My throttlebody HAS to come from the other end, for my laterally mounted engine.
  • Mars
    • Apr 2004
    • 826
    I am not sure, it should bolt up, if not :
    • StudlyCamaro
      • Nov 2003
      • 692
      yes it will bolt on backwards
      3.4L camaro some goodies
      • Quintin66
        • Aug 2004
        • 56
        Man, that will be super cool if it does. That will alleviate a load of fabbin'. Thanks guys.............Quintin
        • smilinguy99
          • 147
          Here's some pictures of the thing you are talking about:
          sg99
          He who dies with the most toys is still dead.
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            You need to turn the upper AND lower around. Yuu will want the thermostat in the front aswell.
            • Quintin66
              • Aug 2004
              • 56
              Your right, the lower would have to be turned also. It's funny, the picture of the complete Motor/Tranny setup doesn't show the swap, but the close-ups do. I bet thats gonna be an electrical funhouse. But I geuss all I would have to do is plug the injectors in for their prespective spot.
              • TheProfessor
                • 869
                i thought the water pump attached to the LIM on 3X00 engines
                I Like V660s
                Does Chevy make beer
                ~Jayme~
                  • 9191
                  Nope. Attaches to the front cover.
                  • Quintin66
                    • Aug 2004
                    • 56
                    I will be using the Killerbv6 timing cover, along with they're water pump. It's expensive, but necessary. It uncovers the motor a little, kinda gives it a Micro-V8 look. After I cut, grind, and re-weld the original 3400 exhaust manifolds to fit my triumph, hopefully I can find some sidepipes that will bolt up. About the only thing I haven't figured out is the correct clutch for combo of #1-94 2.2l 5sp bell, #2- 85 mustang t5 w/ 10 spine input shaft, and #3- still using the hydro-clutch.
                    • geoffinbc
                      • 5831
                      One from a 60* V6 S-10 will do the trick for you. I dont think the T5's had different input shafts.
                      • Guest
                        There are a few different input splines for the T-5. S-10 660 is different from S-10 4.3, which is different from Ford V8 T-5 (Which I beleive there was also a few variations just for the Ford V* T-5), which is different from the Ford V6 T-5, etc.
                        • Quintin66
                          • Aug 2004
                          • 56
                          I think what I'll try to do is find a t-5 from the 94 or 95 that was stock for that bellhousing, that way, I can use the stock clutch parts. All I will have to do then is have the flywheel bolt holes matched to the new clutch by a machine shop. AND, make sure I've got the right pilot bearing...........Sound Good?
                          • geoffinbc
                            • 5831
                            The 4.3L never used the T5 did it? I though it started in 88 with the NV line of trannies. But Camaro's did use T5's behind their V8's so that would be just like a 4.3L one if it did exist.
                            • Quintin66
                              • Aug 2004
                              • 56
                              My concern is the spline count. The teeth in the clutch plate must match the spline of the input shaft. I have read that the 80's and early 90's input shafts used primarily 10 spline shafts. They were alledgedly shorter than they're '93 and up counterparts. I read somewhere that ford went back to a longer shaft at some point, or some applications. I have never seen one, so I don't know for sure. That's just what I've read in the last few months, researching this 3400/spitfire swap.
