3100 timing gear or hd timing?
  • kill_them_all
    • Jul 2004
    • 96
    I was checking out jegs and I came across:
    http://www.jegs.com/cgi-bin/ncommerc...89&prmenbr=361
    Cloyes HD timing set
    and
    http://www.jegs.com/cgi-bin/ncommerc...56&prmenbr=361
    Proform Gear drive
    They both say they are for a small block chevy. Will these work on the 189 3100? Thanks.
  • Guest
    No.
    The cam and crank gears are larger for the SBC, plus you would need a different length ting chain, due to the cam being a longer distance away from the crank (center to center) on teh 660, as compared to the SBC. IIRC the difference was about 1 7/8".
    The cam gear bolt pattern is the same between SBC and genI/II 660 cam. The crank snouts also share the same dimentions.
    I looked extensivly into this to attempt to modify a SBC (or other application) timing belt, to work on a genI or II 660, so far I'm stillk at the idea stage, due to teh cost being prohitive t experimentaion at this point.
    There is some good new however, Cloyes does make a direct fit timing set for the 660. It has received mixed reviews on this site alone, however.
    I have used OEM replacment myself, I actually have the FWD (genII) set in my truck, which is narrower than the genI RWD (longitudily mounted) timing set, mix up at ordering, but has not failed so seemed to have any excesive wear. It is a Federal Mogul set.
    • dbtk2
      • Feb 2004
      • 349
      I just used new factory gears/chain when I did my cam/topend swap. My factory parts had ~75k on them and still looked like they were in very good shape, so I didn't see why I shouldn't just repalce it with the same parts.
      Although gear drive on a 660 would be pretty sweet.
      Shawn
      99 Grand Prix GT
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        The good old silent chain is always best. It stretches the lest and operates without fault. What do you think you are gonna gain for a gear or belt drive, honestly? Do you like replacing belts or perhaps the wine of straight cut gears wakes you up in the morning?
        • malibu97ss
          • Oct 2004
          • 16
          Kill then all, i got your back on this one, I would go for the straight cut gears...I think they sound sweet! But the timing set on the 3x00s is pretty solid, money is probaly better spent on something else
          97 malibu 3100v6 auto
          p/p\'ed upper and lower plenums
          custom intake
          nitrous...dry...never a problem
          2.5 in cat back, brullen muffler
          eibachs springs, falken ze512 225\'s
          other misc. toys
          • kill_them_all
            • Jul 2004
            • 96
            I am going to use the oem, I was just pondering these two things. Thanks for the imput.
            • ProjectMM
              • Mar 2004
              • 170
              Also one thing to think about, with gear drive you can lose up to 8 hp at the wheels! so I don't think that it's worth it anyway
              2002 Pontiac GrandAm GT1
              3400 v6
              TOG headers
              RSM 62MM T-body
              FFP underdrive pulley
              GRANATELLI MAF
              Ported upper intake
              MSD DIS 4 ignition box
              MSD Wires and coils (pending)
              Venom high flow fuel pump (pending)
              • v6h.o.
                • 1418
                LOL. the Stock Silent link chains are garbage...
                stock timing chain gear on left with 25,000km's and new replacement on right..
                the chain is supposed to be right tight against the guide
                timing chains are supposed to be able to be pulled OFF the gear this much right?? right?? ha no...
                this like i said was a stock timing chain with 25,000 some Kilometers.. the timing chain gear that was put in Last summer in Sept the one that is pictured there New beside the old shit is Just as bad and needs replacement as well right now and it has only recieved 15,000 Km's at most maybe... Stock are shit, this will be #4 if i replace it again.
                Colin
                  • 9186
                  That's about how loose mine was after ~20,000 miles. I had used a Cloyes (sp?) stock replacement.
                  • geoffinbc
                    • 5831
                    WTF. My Camaro 3.4L motor and My 2.8L S-10 were nothing like that. Both after more than 100,000 kms. I could have left it alone if I was cheep enough.
                    We just pulled Lloyds 3.1L out with 150,000 kms and it was nothing like that.
                    I'm sorry but that is just not normal. Is there maybe an end play problem with the crank? Perhaps the gears are out of alignment. That would acount for excessive chain wear. In millwright school we learn about alignment problems
                    • v6h.o.
                      • 1418
                      I know its not normal. my original timing chain from the original engine way back when when torn down didnt look that bad and it was 200,000 kms on it.
                      customers cars that i work on all the time dont have issues. My feelings are the stockers are not supposed to be abused and used the way i put them through the paces.
                      The crank does not have any abnormal End Play.
                      what exactly do you refer to when you say "gears out of alignment" ?
                      meaning the distance from crank to cam gear? or something different?
                      Colin
                      • LA1 Z24
                        • Jul 2004
                        • 24
                        LoL, nice chain Colin. THat's nothing compared to the chain that was in my old 3.1. I took the cover off and the chain was so stretched, I could take it and twish it almost 180* while it was still on both sprockets. That's what 120,000 miles on a stocker can do
                        • geoffinbc
                          • 5831
                          Well for kicks run a machineists rule across the cam gear face down to the crank gear. See if it aligns. Maybe the thrust surface on the back of the cam gear is out of wack. Or perhaps the crank gear was not pressed on all the way. Just take a look-see. Next I would put a dial indicator on the cam gear face and check for run-out.
                          • v6h.o.
                            • 1418
                            The crank gear was installed all the way. i should know i have installed all of them over hte years myself. and i always even ensure its fully seated.
                            I'll run the rule across If i tear into this thing over the winter while the car is apart. just to see if there is any out of whack-ness.. quite possible.
                            Colin
                            • XLR8ING
                              Too Stupid To Quit!
                              • 268
                              Ok, so what chain is the best?
                              I'll be changing mine this winter since I'll have the motor out again soon. It's got the Fed-Mogul stock replacement in it right now and has run fine thus far for years.
                              Franz
                              1990 Z24-NA 3.1L
                              14.72 @ 92.24 MPH
                              14.89 @ 94.92 MPH
                              The boost is coming....
