Performance input needed
  • fierofanatic88
    • Jul 2004
    • 82
    Hello everyone I am pretty new to the forum.I just got a 3100 for my 88 5spd fiero and I am just finishing the tear down on it.I have done some reading here and the 3100 I have is from a 95 monte.Got a pretty good deal I think on a 35,000k engine.So my goal squeeze 200 to 210 hp out of this engine. Possible?
    Does anyone have pictures of the S&S headers.I want to see if they'll work with my setup.Izu 5spd tranny. 17hp here correct?
    Realistically how much gain would be had by roller rockers? 5-6hp?
    Where on the engine next would I look to squeeze some more hp?
    Larger Throttle Body? 5-10hp?
    Any help would be great.I want to decide on my engine changes before I send my memcal to get programed.
  • TheProfessor
    • 869
    get the 2000+ heads and intake
    I Like V660s
    Does Chevy make beer
    ~Jayme~
    • fierofanatic88
      • Jul 2004
      • 82
      Do I need both upper and lower intakes? The difference in the heads are larger exhaust ports and roller rockers correct.I can get those from both the 3400 and 3100's correct?
        • 9191
        All 3400 and 00+ 3100 upper and lower are identical. 93-99 3100 are identical. BUT, a 93-99 3100 uppe/lower will NOT bolt to a 3400 lower/upper. So you must match those.
        All 3400 and 00+ 3100s have roller rockers and larger intake valves. 94-95 3100 heads have stamped rockers. 96+ 3100 heads have roller rockers. All of the heads have the exact same size D-shaped exhaust port.
        • fierofanatic88
          • Jul 2004
          • 82
          So I just need the upper and lower from a 2000 + 3100or3400 and the heads.Then I just need to get the adapter in order to use the older style egr correct.What are the approx gains on the top end swap anyone know?
          Did I also read somewhere that the Throttle body from the 3400 is larger and will bolt to the 3100 intake?
          Does anyone have pictures of the S&S headers.Very interested in this bolt on if it will work on my application.I have some reserves about the crossover if it uses one.Can anyone help me with a pic?
            • 9191
            http://60degreev6.com/hlperf/Beretta...0Work/Headers/
            • fierofanatic88
              • Jul 2004
              • 82
              Wow those things stick out alot.Does anyone know how far they stick out at the bottom in reference to the bottom of the oil pan?Okay so I have the headers the gen III 2000+ top end anywhere else I can look for xtras hp.without new cam .
              I am using the OBDI 730 computer .If there is anything else LMK
              THanks a bunch.
