Cam shafts
  • twistedxknights
    • 5
    Cam shafts
    I was wondering witch motor came with the roller lifters or maybe if there is a aftermarket performance cam that allows for use of the roller lifters..
    ASSUME = ASS oUt of you and ME
  • robby1870
    Squaddoosh
    • 584
    3100s and 3400s came with roller lifters. There are no, AFAIK, aftermarket roller cams for the 3100s. Regrinds are available though
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      What engine do you have now? If you have an engine without roller lifters then hydraulic roller lifters will not work. However you can use solid roller lifters and a roller cam. Crane and Comp both make them.
      • twistedxknights
        • 5
        my 85 s-25 jimmy has a 2.8L with the edlebrok manifold and the holley 390 4-barrel carb... Automatic trans... .. just wasn't too sure what engines cam with it stock...
        • geoffinbc
          • 5831
          Yea you just have a plain jane hydraulic lifter cam. I would not recommend any solid lifter can for a street engine.
          Something like a Crane 260-2 would be nice.
          • robby1870
            Squaddoosh
            • 584
            If you do any other internals, check out the crane 272-2
            Robby Whitesell
            2006 Pontiac G6 GT
            • twistedxknights
              • 5
              was giving some thougt to stroking it and maybe a blower... or adding some laughing gas...definatley roller rockers. an headers
              • 614streets
                • 344
                look at schneider cams and lazer. Crane sells the lifters. Im talking about full race roller cams for Iron heads only.
                If your on a budget the 272 hyd flat tappet from paw is they way to go with a blower. Im running a 272 with sbc z-28 valve springs rated to .520 lift , stock diameter, paw lifters,sbc 1.6 roller tip rocker arms and stainless valve set. I have just over 300 in my valvetrain. Roller cam your looking at 300 just for lifters, close to 1000 or higher to go roller(locks, lifters,springs,cam,retainers,etc,not including valves). You decide.
                1992 Chevrolet S10
                2.8 v6 tbi 5 speed
                • Cliff8928
                  • 532
                  One thing i always wondered is what is the difference between solid (roller) lifter cams and hydraulic (roller) lifter cams? What would happen if you used a cam meant for solid lifters with hydraulics?
                  Cliff Scott
                  89 BerettaGT
                  89 Volvo740
                  Cliff Scott
                  89 BerettaGT
                  04 AleroGX
                  • Blackrider
                    • 131
                    Comp is currently working on valve train line including N/A Boost and Nitrous cams.
                    2006 G6 GTP MT6
                    Vector Motorsports ECU
                    Classic Performance 2.5 Inch Exhaust
                    v6h.o. Downpipe
                    Custom Intake
                    • robby1870
                      Squaddoosh
                      • 584
                      Wow, thats good to know for all your 3x00 people!
                      Robby Whitesell
                      2006 Pontiac G6 GT
                      • Blackrider
                        • 131
                        [/quote]Wow, thats good to know for all your 3x00 people![/quote]
                        I know We are all pumped
                        2006 G6 GTP MT6
                        v6h.o. Downpipe
                        Custom Intake
