Recapping the LS1 spring swap debate
  • smilinguy99
    • 147
    #61
    RX11:
    I stand corrected on the production Gen2 springs. However, excessive spring pressure has a very small HP cost. Opening a valve against a heavy spring does require more power, however closing a valve against a heavy spring gives virtually all of it back. There are greater frictional losses to be sure with a heavier spring, but if you are rollerizing the tappets and the axle and tips of the rockers friction and the resulting heat are minimized.
    Thanks for the clarification on the reason for conicals on the LS motors, I was using a fuzzy recollection from a foggy memory.
    Not sure what you mean by obscene, but more pressure keeps you out of more problems. I suppose we'll have to agree to disagree on this point.
    It boils down to this: with more RPM you need more pressure, with more aggressive lift, you need more pressure. What's too much? It's actually hard to say. How safe is too safe? Are you willing to accept some increased wear and a slight HP hit for peace of mind? What's too little? when valves start kissing pistons and the motor goes flat just as you reach maximum RPM. Call me a scaredy cat, but I'd like engine maintenance to be more predictable and on my schedule. I've replaced a couple full sets of bent valves (on V8s) and it was costly and wasteful. I'll take some extra pressure, please.
    My comments in the last post were mostly addressed to the fellow with the crate motor. LS springs in that motor are doable, but there are more options for the iron motor that he might benefit by exploring.
    ikessky:
    Nope the mods ain't done yet. I sent the test heads off and then put a hold on things when another part of the project took a different direction. The fellow I sent them to thought the 1.800" valves would be no problem to do, and they may be worthwhile. Anyway they are on hold.
    The 1.460" springs are a viable alternative. They come in "obscene" versions as well as "R-rated" versions. Sorry, no "G-rated" versions. Moderate pressure, high pressure whatever you want.
    There is one thing you would have to get over if you use 1.460" springs. When the valves of the adjacent I/E pair are on their seats, their retainers are .030" apart. Intuitively one might say, "Yipes!, run away!" But that .030" is as close as they are ever going to get. It looks freaky, but it's fine.
    sg99
    He who dies with the most toys is still dead.
    • TurboZ24
      • 299
      #62
      There are the 1.46" springs on mine. They really arn't all that close together.
      Curtis
      91\' Turbo Z24
      http://www.turboz24.com
      • smilinguy99
        • 147
        #63
        Originally posted by TurboZ24
        There are the 1.46" springs on mine. They really aren't all that close together.
        Sorry for not being specific. I was speaking about the aluminum heads. If you follow the link I posted earlier, you'll see what I mean. They are quite close.
        Your photo emphasizes my point that the iron head has more spring diameter options than the aluminum motor. There are no clearance issues between the springs.
        sg99
        • Rhedalert
          Dr. Feelgood
          • 1574
          #64
          there's my gen-3 AL head with 1st gen LS6 springs installed.
          Brian
          3400 SFI V6, 4T60e
          • blackbombshell95
            Kaiō-ken X 10
            • Jun 2004
            • 1386
            #65
            have we found spring seats that require no grinding to fit?
            02 GTP - 90* > Failboat
            www.blackbombshell95.com
            • AaronGTR
              boost lover
              • Jan 2004
              • 708
              #66
              For which head? Gotta be specific... but for all the later year AL heads yes, we know what works. I'm sure there are other guys on here that know what works on older heads and have part numbers.
              '97 Grand Prix GT 3800 (sold)
              Gotta love boost!
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                #67
                newer heads of course. 2000+ 3400 heads
                • AaronGTR
                  boost lover
                  • Jan 2004
                  • 708
                  #68
                  For 2000 and older heads, stock LS1 springs seats and the 3.1L "T" valve seals will work. For 2001 and newer heads that have the larger diameter valve guides, you will need the chrysler 318 valve seals and spring seats for a 81-87 toyota land cruiserwith the engine code 2F. Again, these are just parts we know will work. There are probably several other parts from other sources that will work. You would just have to find a car with the same valve guide diameter, valve stem diameter, spring diameter, etc. It would just take some research.
                  Gotta love boost!
                  • blackbombshell95
                    Kaiō-ken X 10
                    • Jun 2004
                    • 1386
                    #69
                    i have the chrysler 318 valve seals.
                    HOw do i tell if i have the early 2000 heads or the 2001+ heads?
                    • ikessky
                      • 614
                      #70
                      http://www.60degreev6.com/modules.ph...rtid=32&page=1
                      Take a look at the part numbers.
                      • 91BerettaGT
                        • Oct 2004
                        • 40
                        #71
                        I got a felpro number for the Stem seals,... Making sure they are the right one...
                        Brought it up as a 96 Dodge Dakota with the 318.
                        "Fel Pro SS72844"
                        So I can grind the LS1 Valve seats right? because I can't wait 2 days to get the seats in stock I need the car for tuesday...
                        Rob
                        \'91 Chevrolet Beretta GT 3400 5 speed
                        R/t .506
                        60\' 2.195
                        330\' 6.138
                        1/8 9.390 @ 76.48
                        1000\' 12.183
                        1/4 14.553 @ 94.01
                        Http://www.domesticcrew.com/660
                        • 91BerettaGT
                          • Oct 2004
                          • 40
                          #72
                          "Fel Pro SS72844"
                          Alright, that Fel-pro number works. :-D
                          I drilled out the LS1 Valve seats. Have to be careful doing this because I split one (don't worry i replaced with new and redrilled it.)
                          Paid $40 for a Unibit with a lifetime warranty :-) and cause i had to spend money ...
                          Does anyone have torque specs on the Rocker studds?
                          Rob
                          R/t .506
                          60\' 2.195
                          330\' 6.138
                          1/8 9.390 @ 76.48
                          1000\' 12.183
                          1/4 14.553 @ 94.01
                            • 9188
                            #73
                            All the torque specs are in the PUSHROD/SPECIFICATIONS area for each engine.
                            • 91BerettaGT
                              • Oct 2004
                              • 40
                              #74
                              Yeah, cool, I actually searched over at v6z24.com and one of them said to come here and thats how i found it. Duh me should've searched here because it's DIRECTLY related to the 60° V6 as compared to a Z24 Which I do not own lol....
                              Rob
                              R/t .506
                              60\' 2.195
                              330\' 6.138
                              1/8 9.390 @ 76.48
                              1000\' 12.183
                              1/4 14.553 @ 94.01
