bigger valves
  • TheProfessor
    • 869
    bigger valves
    hey does anyone know if the gen 3 heads can be ported for and fitted with larger valves and if so where such valves would be available
    I Like V660s
    Does Chevy make beer
    ~Jayme~
  • robby1870
    Squaddoosh
    • 584
    3400 heads have the 1.76 intake valve, but exhaust is still 1.42. Im not sure how to go about fitting bigger valves, but given how close the valve seats are to one another, there's not much room.
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
    • TheProfessor
      • 869
      yeah i know they are close but so are the gen 2
      I Like V660s
      ~Jayme~
      • TheProfessor
        • 869
        ok so far what i have found out is that there is are 1.3mm oversized intake and 1.5 oversized exhaust valves when i find out more about them and whether or not they will be usable without major mods ill post
        I Like V660s
        ~Jayme~
        • RacerX11
          • 1060
          See my post in this thread regarding searching for bigger valves: http://60degreev6.com/index.php?name...424&highlight=
          Marty
          '99 Z-28 - Weekend Driver
          '84 X-11 - Time and Money Pit
          Quote of the week:
          Originally posted by Aaron
          • smilinguy99
            • 147
            Here's a link that shows just how much room there is to put bigger valves in a GenIII head:
            He who dies with the most toys is still dead.
            • TheProfessor
              • 869
              ok heres what ive found out
              you can get oversized valves of 1mm larger for both the intake and exhaust
              they can be used without any modifications to the head
              so thats 1.8 intake and 1.46 exhaust
              now im wondering what the result would be in using these size valves
              I Like V660s
              ~Jayme~
              • RacerX11
                • 1060
                If you don't modify the head by enlarging the throat of the valve seat, or installed larger seats, you won't gain any flow....you will probably end up hurting flow.
                Marty
                Quote of the week:
                • TheProfessor
                  • 869
                  yeah well youll have to do that stuff in order to take advantage of them
                  what i ment was that they would drop right in and not cause any interference problems
                  I Like V660s
                  ~Jayme~
                    • 9190
                    Any interference seated or during 5k+ revs?
                    • v6h.o.
                      • 1418
                      so thats 1.86 intake and 1.46 exhaust
                      Woah. slow down there trigger.. Your comparing apples to oranges.
                      1.76 is INCH. = 44.704mm, thus 1mm oversized valves(which are made to replace valves that in heads that have worn out valve seats so that the new seat can be cut slightly larger) would equal 45.704mm in orange form which then equates back to the apple form of 1.799 inch, which is just .039 inch larger than stock. get a feeler gauge out and measure this amount.
                      Colin
                      • TheProfessor
                        • 869
                        no interference unless both valves are at .400 inch lift or more at the same time
                        which should never happen unless there are problems with the valvetrain
                        colin.....so are you saying that it wouldnt be worth trying out larger valves
                        and what do you mean apples and oranges
                        I Like V660s
                        ~Jayme~
                        • v6h.o.
                          • 1418
                          intake valves are 1.76inch. you posted 1mm oversized valves =1.86 inch i was simply pointing out you were confusing two different forms of measurement and getting them all jumbled around. 1mm oversized equals the number you now edited your post to as i pointed out..
                          Colin
                          • TheProfessor
                            • 869
                            oh ok gotcha
                            didnt know what you ment
                            yeah just made a mistake when typing 1.86
                            I Like V660s
                            ~Jayme~
                            • TheProfessor
                              • 869
                              http://www.novia.net/~sparks/heads/GEN3_HEAD_PARTS.html
                              where did you find this
                              anyway to contact them
                              I Like V660s
                              ~Jayme~
