Turbo oil pressure
  • darkroom
    • Feb 2004
    • 19
    Turbo oil pressure
    I'm going to turbo my 3400 and i was wanting to know where everyone is getting the oil pressure for the turbo oil inlet.
    Thanks
  • Guest
    I "T"ed off the oil pressure sender.
    • oil pan 4
      • 84
      Electric oil pump.
      Seth
      Camaro 1
      85\' 3.4L, T-5, 3.42gears
      Mods at work on,
      car domain site 03/13 Saab intercooler flow numbers.
      85\' IROC Z28 Ttop 5.0L, auto mostly stock.
      • dbtk2
        • Feb 2004
        • 349
        I'm pretty sure mine is t'ed off the oil pressure sending unit.
        Shawn
        99 Grand Prix GT
        • darkroom
          • Feb 2004
          • 19
          Yesterday i was looking at my engine an i happened to notice a bolt near the oil filter the bolt had a fitting for a rachet so i was wondering if i remove that and put a nipple on there i could use that for the oil pressure. i'll test this out this weekend if i have time.
          • TurboZ24
            • Dec 2003
            • 299
            There is a plug above the oil filter on some 3.1. Sometimes that was used for the oil pressure sensor, sometimes the oil pressure sensor was located on a plate between the motor and oil filter.
            Yes, you can use it for the oil supply for the turbo, that's what I do on mine.
            Curtis
            91\' Turbo Z24
            http://www.turboz24.com
