would i be able to
  • geldartb
    The Situation
    • May 2004
    • 1994
    would i be able to
    the question is. is there anything out there that would fit the 3100/3400 platform that anyone knows of or would these fit w/o screwing anything up
    sorry its these SLP V6 1.8 ratio rocker arm package
    under the valvetrain section
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    No that will not work.
    • geldartb
      The Situation
      • May 2004
      • 1994
      ok thanks thats all i needed to know. i just stumbled across these when i was looking around on the net today. would you know if there is anything out there like this for the 3.1/3.4
      99 Grand Am GT
      • dbtk2
        • Feb 2004
        • 349
        You can get 1.6 rockers, but thats as big as they go. But most of the 3X00's had 1.6's from the factory anyways.
        Shawn
        99 Grand Prix GT
        • sharkey
          • Jun 2004
          • 2061
          i know guys have used sbc roller rockers (they are pretty well the same). they make them from break in 1.3:1, 1.52:1, 1.6:1 and even 1.7:1. im not sure if its possible, but you may be able to use 1.7:1 rockers.
          • geldartb
            The Situation
            • May 2004
            • 1994
            does it matter on the sbc chevy size or just any 1.7 roller rocker for a sbc
            99 Grand Am GT
            • geoffinbc
              • 5831
              It matters. Old 660's with ball picot rockers could use any SBC rocker in combination witht eh stock pivot ball and go from there. Also any small block stud mounted rocker can be used when you get to correct conversion studs.
              But pushing the ratio limits may get you into valvetrain geometry and clearance issues. On 3400 you should be able to bump to a 1.7. But on a gen I or II jumping from 1.5 to 1.7 needs some care
