O-ringing the block or "how to keep boost under the hea
  • donk_316
    • Mar 2004
    • 427
    Anyone have experience with this? This is the first boosted motor i have built and now im deciding between copper head gaskets (retarded prices i might add) or O-ring.
    When you O-ring the block i know your machine the block and head then use a SS "o-ring" but what about the rest? Do you still use a typical head gasket?
    Anyone with experience with this?
    1984 Indy Fiero 3.4L
    13.7 sec @ 98 mph
    *ALL THROTTLE AND NO BOTTLE*
  • 614streets
    • 344
    Yup I had it done on my 355. They cut a reciever groove in the head and another wire groove in the block deck. Then wire is inserted into the deck groove and a copper gasket is added When torqued to spec the copper will be formed against the stainless steel wire in the deck and crush up into the reciever groove in the head.
    I reccommend flat out gaskets. They are silicone laminated copper gaskets. The silicone laminate aids in sealing water jackets.
    1992 Chevrolet S10
    2.8 v6 tbi 5 speed
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Probabally overkill. But I guess application will dictate wether it is actually needed or not.
      • 614streets
        • 344
        BTW Instead of copper and o ringing the v6, you might want to check out solicor or cometic.
        1992 Chevrolet S10
        2.8 v6 tbi 5 speed
        • Hybird
          • May 2004
          • 36
          I have recently asked about this on a couple forums. Seems like too much hassle for me. But the main idea is to use this technique with copper gaskets. Hopefully tomorrow I can call the cometic guys and get a quote on how much one of their gaskets will cost for my 3.1. Its says right on the web site that these gaskets are ideal for aluminum (heads) to Cast iron (block) applications. So I think thats my choice
          Jordan
          • 614streets
            • 344
            Yup. I talked with the machine shop that did the work on my 355 ( www.fowlerengines.com )and while I was there I told them I was overdriving my gmc and direct port or dual plates and he gave me two options o ring or fel pro wire locs. For my application it was choosing between the possibilty of blowing a head gasket and sitting out a competition race or never blowing a head gasket. If you run copper with or w/o a silicone laminate you need to occasionally check the oil for water contamination.
            For a mildly boosted v6 cometic or solicor will definately work. BI/ metal.
            http://www.mrgasket.com/pdf/Gaskets.pdf#search='solicor%20gaskets'
            1992 Chevrolet S10
            2.8 v6 tbi 5 speed
            • TurboZ24
              • 299
              I've never had oil contamination issues with my copper headgaskets, just the occassional tiny ass leak down the side of the block. Still pisses me off, though.
              Curtis
              91\' Turbo Z24
              http://www.turboz24.com
