Cam shaft question/3.1 buildup
  • Doubt_Incarnate
    I still watch ROBOTECH!
    • Jan 2005
    • 1130
    #31
    crane 25759-12 , the -12 denotes 6cyl application,i missplaced my invoice. i think i got mine from jegs (then i learned summit is usually cheaper). let them know what its for they might know what your talking about but that part number is off my box. you get the rockers, and the kool nuts with locking setscrews, and your instructions. it says something in the instructions about rocker arm studs from the aluminu heads being bottleneck, or something, and you need straight shank ones from the iron heads. im pretty sure the kit came with them, since the nuts were there, might aswell match them up, but dont quote me on that, like i said i lost my invoice.
    like i mentioned befor, i dont think these will work with the 3x00 heads unless you do some machining first and screww in the studs. i seem to remember my 3100 project heads have a pedestal mount thing where the bolt goes through the rocker pivot and it is torqured down.
    i just checked summit, they list them online: CRN-25759-12 Rocker Arms Gold Race Chevrolet V-6 80-94 2.8L/3.1L 1.6 Ratio 3/8" Stud
    $324.39 but the studs ar listed seperatly, never hurts to call and ask ?'s. try jegs too, i dont remember ordering the studs seperatley. ask ask ask, its waht ?'s are for
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      #32
      You can get Crane Cams Gold Race Roller rocker kit. It comes with studs. You will need to convert to the adjustable studs they provide and also install guideplates. But since you have stamped rockers on your 3100 then you will have guideplates. So your all set.
      However you will need to clearance the lower intake.
      Above are pics of Cranes rockers on a 2000 3400. As far as I know Lloyd and I are the only ones to do this modification.
      • Stevesr
        • Jan 2004
        • 117
        #33
        I take it that there is no problem with the valve covers fitting over them?
        SteveSr
        • geoffinbc
          • 5831
          #34
          Nope not at all. Valve covers have plenty of clearance. It is only the 4 points on the lower intake. They hit the back of the rocker.
          • Stevesr
            • Jan 2004
            • 117
            #35
            What does it take to convert the studs?
            SteveSr
            • geoffinbc
              • 5831
              #36
              Convert? There is nothing to convert.
              Remove the stock ones and install the Crane ones.
