Extrude Honing and or Port and Polish
  • ProjectMM
    • Mar 2004
    • 170
    I was looking for some advice on getting my upper and lower intake extrude honded. on Extruded hone.com they talk about how important it is to have a evenly tuned manifold. I'm just wondering if any one has done this? and if so would you recomend it?
    The guys with older Camero manifold, say they used to get 15 to 20Hp by haviong this done?
    I've allready got my upper Ported and polished, ( on the TB side and some of the runners) but was looking into having this done to get the most HP! I'm
    thanks for all your help!
    2002 Pontiac GrandAm GT1
    3400 v6
    TOG headers
    RSM 62MM T-body
    FFP underdrive pulley
    GRANATELLI MAF
    Ported upper intake
    MSD DIS 4 ignition box
    MSD Wires and coils (pending)
    Venom high flow fuel pump (pending)
    • 9191
    RE: Extrude Honing and or Port and Polish
    Last time I looked, it was like $500 to do an EFI manifold. If you are willing to shell out that much money, then go for it. It is a great process. Problem is, most people aren't willing to spend that much. They are more apt to spend a 1/4 or less of that and have it "pretty good" by just normal porting.
    • 614streets
      • 344
      Extrude hone is a good thing. If you had It done and put in a cam matched to to the rpm range the extrude hone. The Extrude hone will allow the engine to breathe more air all you have to do is brain more in there with a new cam. If you have it done Id be cool to see the pictures ,before and after.
      1992 Chevrolet S10
      2.8 v6 tbi 5 speed
      • feavs
        • 69
        Wasn't there a guy with a berretta that had his upper/lower intake manifold that was extrude honed? And he ran in the 14's? I can't remember...
        feavs
        • Thumper
          • Oct 2004
          • 8
          I believe that would be Norm '88 GT
          • ProjectMM
            • Mar 2004
            • 170
            Well if any one know's how to get ahold of that guy, I'm really intersted in finding out how much improvement he got from this!
            3400 v6
            TOG headers
            RSM 62MM T-body
            GRANATELLI MAF
            Ported upper intake
            • heavywoody
              • Feb 2005
              • 33
              http://www.beretta.net/performance_c...orms_88_gt.htm
              There is a link to Norm's Beretta work prior to his current SC setup. Unfortunately, it doesn't state after #'s regarding HP/TQ increase from the Extrude Hone setup.
              Geoff Morrow
              95 Z26 3400 5spd BSpeed Profile
              • Doubt_Incarnate
                I still watch ROBOTECH!
                • Jan 2005
                • 1130
                brain storming last night, couldnt sleep. does anyone make race-flo valves for our heads? probably not, so ive been thinking of grinding the valvestems down where its in the airflow path to help a little in that department. theres a potentialy free mod.
                • ProjectMM
                  • Mar 2004
                  • 170
                  Just to let everyone know, I got an E-mail back from Extrude hone. they quoted me a price of $650.00 for both upper and lower. it seems like a lot of money, if it's not going to make a big difference!
                  he did state that having this dune if your going to do a cam swap, or go to a bosted application, this would help out alot!
                  3400 v6
                  TOG headers
                  RSM 62MM T-body
                  GRANATELLI MAF
                  Ported upper intake
                  • v6h.o.
                    • 1418
                    With your "large port" stock 3400 style manifolds. Your not really choked off that bad anyways. Norm had the Extrude hone done on his stock gen2 manifolds which really are an obstruction.
                    You can get the full lenght of lower intake manifold runners ported/smoothed out to help aid in flow. With the right tools this can be done. I do it all the time.
                    However yes the Plenum really can't be fully ported inside and out due to constraints of getting in there properly.
                    The runners and t/b opening are about all that can be enlarged/smoothed out via conventional porting. Which is just fine for what you want to do.
                    I run 13's on a 3.1L with only normal smoothing of the runners on the plenum/LIM.
                    for 650$ USD, not worth it for a good flowing intake like what you have.
                    I charge 200Can$ for smoothing the full lower intake/gasket matched, and smoothing the plenum runners/gasket match and enlarging the T/b opening.
                    Colin
