Who makes an aftermarket Distributer for 95 camro 3.4 block? MSD? If so which one is best?
Aftermarket Distributers?
RE: Aftermarket Distributers?
never heard of there being any aftermarket ones. if you are running a carb and no ecm, you will need to find a distributor from an 80-85 that is vaccume advance and does not have the pickup coil in it. this is about your only bet. they do have weights in them and you can tune the spark curve through the weights.
No all an ignition box does is take a spark signal and creates a capacitive discharge through the box. Most also create multiple spark. The box then has the ability to adjust timing based on certian inputs. For example 1* retard of timing for every pound of boost applied.
There are no aftermarket distributors avalible. But there really is no need.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
So were early generation distributors. Is this casting any beter than stock? A rebuild perhaps? Or all new crazy high output distrubutor?1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
The only info I have, have already posted, they don't look rebuilt, but cleaners can do wonders.Originally posted by betterthanyouSo were early generation distributors. Is this casting any beter than stock? A rebuild perhaps? Or all new crazy high output distrubutor?
Even still rebuilts are generally very good.
