3.1-3.1 Turbo
  • 96monte+94euro
    • Mar 2005
    • 9
    3.1-3.1 Turbo
    what is required to swap a TGP turbo system into a 94 Lumina Euro 3.1?
    i figured maybe i could just swap the manifolds, x-over, DP, and turbo stuff
    or do i need to put the whole engine/tranny/PCM combo in?
  • skeeterone2
    • Jan 2004
    • 115
    RE: 3.1-3.1 Turbo
    new injectors the stock 3.1 injectors dont have enough balls there is a thread around here somewhere that has the # injecors that you need and i would upgrade your fuel pump... and chip from the TGP or an aftermarket one... i think a MAF... i looked into this a while ago... if you know of a tgp setup for sale be leary of the crossover pipe they crack and you cant really tell... which will add another 600 onto your build because of having to get a new one.. there is a company that makes them but they are expensive. you dont have to swap the whole engine and tranny... many have debated wether or not the tgp 3.1 engines had special tolerences for the internals... but as far as i know nobody has found out yet. you will also most likly have to rebuild the turbo. how many miles do you have on your current engine?
    There might be something eles i missed... im sure sombody will fill the rest in. or correct me if im wrong.
    91\' Mazda miata.
    92\' Lumina (sold)
