pushrod mods for 2k5
  • Froggx
    • Jul 2004
    • 385
    saw a post of similar title over in dohc perf. and had to ask
    What do we have in store for our little valve deprived 6-bangers this year?
    As for mine, if I ever get it back together:
    (start with a 3400)
    Slightly ported upper and lower manifolds
    Lightly p&p heads
    Manifold back exhaust
    CAI
    Underdrive pulley (no power steering to boot)
    3500 plenum w/ 65mm TB
    LS6 Valve Springs
    180F thermostat
    Upgraded injectors
    Custom chip
    Custom cam regrind
    And if my savings account recovers quickly enough I could be seeing a little gauge that says "10 psi" on my dash by august along with a drastic increase in performance.
    So what are you doing? Go ahead and post up.
  • StudlyCamaro
    • Nov 2003
    • 692
    RE: pushrod mods for 2k5
    buying another car to drive daily first and formost
    -pulling the motor out of the camaro
    -installing the 3300 RPM stall torque converter that i got off ebay over a year ago, but have been afraid of on a car that gets a lot of highway miles
    -putting my new poly lower control arm bushings in to try to defeat the wheel hop i keep getting
    -using a megasquirt computer tune the car
    - possibly spray the shit outta the stock motor till it breaks
    - possibly assemble my 3.4L/3400 hybrid.. not sure if i will have the $$ for it this summer or not
    3.4L camaro some goodies
    • sharkey
      • Jun 2004
      • 2061
      my 86 z24 is getting an old school motor built starting with a fiero 2.8l HO
      -probe sportsman race forged pistons, 9.5:1 compression
      -speed pro rings and bearings
      -arp rod bolts, main studs and head studs
      -beam polished rods, balanced rotating assembly
      -race ported big valve iron heads
      -stainless valves
      -comp cams 260h complete cam kit (cam, timing set, springs, lifter, locks, retainers)
      -crane cams sbc full roller rockers
      -port matched fiero intake
      -bigger throttle body (unknown as of this point)
      -msd digital 6 box
      -clutchmaster stage 3 ceramic clutch
      -custom built headers
      the car itself will go through a massive transformation in handling, interior and exterior, mostly be later this year
      -koni yellow adjustable struts
      -urethane bushings
      -92+ j body front brakes (or mabey caddy sts brake swap)
      -figure out a rear disk swap (daytona mabey)
      interior
      -racing seats
      -fold down bench seat, recovered to match racing seats
      -short shifter (not a cut shifter)
      -redesign sterio setup
      exterior
      -custom side skirts will functional brake ducts
      -different spoiler (possible a modded dodgeshadow wing)
      -repaint different color (i have it picked but its a secret)
      that will likely be done by this time next year
      2006 major project- Faugol supercharger kit for s10 modded for multiport efi.
      • hamondale
        • Nov 2004
        • 93
        Just roller rockers on my 3.4 crate. Maybe Crane, maybe Comp Cams. Nice to have all of the pros and cons and how tos here.
        Hamondale
        Third Rail... your ride is here.
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          Hedman Headers with new 2.5" exhaust. Fageol Supercharger whenever 614 gets em in stock. Did the Traction bars last weekend that was a pretty sweet mod.
          • JamesonGT282
            • Jan 2005
            • 208
            As we speak I am working on a full rebuild of my Getrag. I bought a 8lb flywheel and this week comes a Spec Stage 2 clutch. I already have new OEM cables waiting too.
            I also worked out a deal with Rebel to take his TGP setup. It includes everything including a Saab intercooler and BOV. I am fairly certain it will crack the 14.0 mark at 10psi.
            '91 Beretta GT 282 swap GONE
            '98 BMW M Roadster stage 2+ boosted
            '06 Saab 9-5 wagon 5mt tuned
            '11 Saab 9-3 XWD tuned
            • Doubt_Incarnate
              I still watch ROBOTECH!
              • Jan 2005
              • 1130
              i'm a loser. i just to want to get my car started again, should be easy if i get off my butt and put a screw or two in, couple gaskets, the plenum, and a working icm and coil. fresh gas and the old 2.8 should be good to go. then if my mental state isn't to severely threatened, i'll finally swap in the 3.1 I built. If the gods smile upon me i'll build a 3x00. if fate conspires against me, i'll just get my J started, sell my T/A to pay off my debts and spend whatevers left on gas and dissapear.
              • Cliff8928
                • 532
                Can the mod list include a new lower intake gasket? I'm thinking of that one just because there's about 35,000 miles on the original 1999 gasket. Also I *NEED* a new trans, and hope to acquire a Torsen sometime in the near future. Then it's just some visual re-freshening and enhancements.
                Cliff Scott
                89 BerettaGT
                04 AleroGX
                Cliff Scott
                89 BerettaGT
                04 AleroGX
                • RacerX11
                  • 1060
                  Tires. Lots and lots of tires.
                  Marty
                  '99 Z-28 - Weekend Driver
                  '84 X-11 - Time and Money Pit
                  Quote of the week:
                  Originally posted by Aaron
                  • farmerz24
                    • Feb 2004
                    • 361
                    turbo my newly created 3100 3rd gen cavy, finish the 84 nissan 720 4x4 pickup with camaro t5, 3100m90, custom headers, and best of all 5 inch chrome stacks@!!! i need pics
