simple cam question
  • JH
    • Oct 2004
    • 66
    simple cam question
    if i bought a crane h-260-2 cam for my 91 3.1 with 2000 3100 top end would i need to change my pushrods or lifters?
  • TurboZ24
    • 299
    RE: simple cam question
    On a flat tappet cam, you always replace the lifters with the cam, so yes, you need too replace the lifters. If you had the 3100 top end on there already with pushrods that fit, you might be able too reuse them, but Colin or someone like that could answer that question better than I (since I haven't done a hybrid yet).
    Curtis
    91\' Turbo Z24
    http://www.turboz24.com
    • sharkey
      • Jun 2004
      • 2061
      the 260 cam is a stock replacment, meant to go right in place of the stock cam, no other mods required (its a good idea to do better valve springs). if you already have a the correct leangth pushrods for the motor with a stock cam, you wont need to change them, they will work.
      • JH
        • Oct 2004
        • 66
        so the crane H-260-2 cam will work without chaning the lifters? even though its a flat tappet cam.
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          What? NO you can't reuse lifters on a flat tappet cam. You don't need DIFFERENT lifters but you do need NEW ones.
          • Doubt_Incarnate
            I still watch ROBOTECH!
            • Jan 2005
            • 1130
            i think i read somewhere the rule of thumb is you can use used lifters on a used cam, or new lifters new cam, and some stupid obvious new lifters used cam, but no, never the new cam used lifters, not worth the saving a few $ to kick the door wide open for problems. it didnt come with lifters?
            • geoffinbc
              • 5831
              You can only reuse the lifters if you put them back on the same lobe they came off of
              • TurboGTU
                • 453
                On a regrind....you need new lifters regardless. Used ones might be pumped up or are leaking badly..no pumping up and the bottom of the lifters is not flat anymore. If it were roller...then that be different...just bleed the lifters before install or check for consistant pump up/blead down.
