head bolt/stud options for 3400
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    I love JBP
    Just send a separate email indicating that you wish to purchase head studs for the 3400 after purchasing this part.
    LOL there is a recipie for a fuck up. That company is comedy.
    • Froggx
      • Jul 2004
      • 385
      Originally posted by betterthanyou
      I love JBP
      I saw the price and closed the window, didn't even read that far down. I agree.
      • geoffinbc
        • 5831
        Well first they actually have to get to the process of shipment. Regardless of what they say it is actually about 4 to 6 months.
        • Froggx
          • Jul 2004
          • 385
          Oh yeah, I factored that in well before the price
          • blackbombshell95
            Kaiō-ken X 10
            • Jun 2004
            • 1386
            why are those studs so expensive? how mu ch would factory ones be??? is their even a big difference?
            02 GTP - 90* > Failboat
            www.blackbombshell95.com
            • geoffinbc
              • 5831
              #21
              Because its J-Body. Order everything through ARP and it will be half that.
              • blackbombshell95
                Kaiō-ken X 10
                • Jun 2004
                • 1386
                #22
                why not just buy them from the factory?
                  • 9190
                  #23
                  Why not just keep the car stock and never do anything with it?
                  There is always something out there that is better than factory components... these studs being one of those items. And as an added benefit, if you pull the heads semi-often, if you used factory, you SHOULD replace the head bolts everytime, whereas the studs you can continue to use over and over.
                  • blackbombshell95
                    Kaiō-ken X 10
                    • Jun 2004
                    • 1386
                    #24
                    learn something new everyday
                    • AaronGTR
                      boost lover
                      • Jan 2004
                      • 708
                      #25
                      Just an update, those part numbers I gave are the correct part numbers. Did the head install yesterday and the studs fit perfectly.
                      '97 Grand Prix GT 3800 (sold)
                      Gotta love boost!
                      • AaronGTR
                        boost lover
                        • Jan 2004
                        • 708
                        #26
                        Ok, another update. I found something interesting yesterday while I was installing my rockers and setting the valve lash. If you are using aftermarket adjustable rockers like me, the bottom of the rockers just touches the top outside head stud (top closest to the end of the cylinder head). My rockers are wider than stock and they have to be adjusted so when you tighten them down they hit. Stock rockers wouldn't have that problem since they are narrower and set lash automatically. The rest of the studs have lots of clearance. My solution was to run a tap in the the holes in the block to make sure the threads were cleaned out, and then cut 1/16" off the bottom of those two studs. After that there was plenty of clearance. I had to do it by hand with a hacksaw and file so as to not heat up the metal and affect the temper. Worked perfectly though.
                        Gotta love boost!
                        • geoffinbc
                          • 5831
                          #27
                          Hmmm got a pic? How much does the stud stick out past the top of the nut?
                          • feavs
                            • Dec 2003
                            • 69
                            #28
                            Mine did the same thing, but with the stock 1.6 roller rockers. I believe it only did it on two of them. Nothing a grinder didn't fix.
                            and
                            kinda shows what I encountered.
                            • AaronGTR
                              boost lover
                              • Jan 2004
                              • 708
                              #29
                              hmm, I didn't think the stock ones would've hit but I guess they do. Mine were sticking up about 1/4" past the nut after they were torqued down. I cut 1/16" off the bottom of the stud so I wouldn't cut off the allen key on the top and they have plenty of clearance now. They are threaded all the way down into the block too, so there's plenty of thread engagement.
                              Gotta love boost!
