cam and OBD II
  • project60degree
    • May 2005
    • 85
    hey guys im talkin OBDII, will that Milzy stage 2 cam work on OBDII with stock ecm? and if soo what are the specs,lobe lift,duration, lobe seperation
    • xonelith
      • 47
      I'm running a stock code on my PCM right now and the car is running 'ok'. I need to adjust the idle (probably add 150-200), but it doesn't stall. I'm getting a little more than 550 lift (exhaust and intake) but this requires the stage II head.
      Currently, Milzy does not want to release the specs of the cam. Since he helped me out so much and I'm really happy with the performance, I'll abide by this for now. He said he will release the specs shortly. Not sure why he doesn't want them released, but it is his product.
      The only problem we have right now is since I have a 2001, the cam sensor doesn't work with this setup. We put the 2003 sensor in, but left it unplugged until a plug'n'play piece is finished testing. I hope to get it soon as I'm running a little rich. There is a thread on GrandamGT.com that describes the details on this.
      I'm just learning the PCM (currently playing with my new software) so I'm not the best person to ask many questions to. You can contact Milzy directly. He's more than willing to talk about his product and help in any way that he can.
      xon
      All Motor 2001 GA GT1
      HPTuners.com
      MilzyMotorsports.com
      GrandsOntario.com
      • AaronGTR
        boost lover
        • Jan 2004
        • 708
        It's designed for an OBD2 car so obviously it will. How well it runs on a stock computer though will probably depend on which stage you get. A stage1 will probably run better without having to do tuning than a stage2. Stage2 will run but you probably won't get the most out of it without re-tuning the pcm. The only ones I know of that are installed yet are 2 stage2 NA cams, and my stage1 boost cam. One of the NA cams is in an '03 and works fine. The other is in xonelith's car. I have a '00, so I have the same problem as him. Any pre-2003 cars will need to change the cam sensor. Milzy is working on making an adaptor that will translate the sensor signal to the proper signal for the earlier sensors so they will be plug and play. In the mean time I'm going to try solving the issue with just pcm tuning using a DHP powrtuner. Just waiting for my programmer to get here.
        '97 Grand Prix GT 3800 (sold)
        Gotta love boost!
