95 was a tricky year. Going into ODBII I guess. I'm not sure if it MAP or MAF. If it is MAP then that would be cool since I can put that supercharger on it like I wanted to.
I'm just not sure hybrid....
Tags: None
ODBII for 3100 is MAF.1995 Grand Am GT
3400 V6 / 4T60-E / Engine Swap
3400 Engine Swap Guide Version 2.5 is Available!
www.3400swap.com
Thanks...
So is 1995 model year ODII? Are the Crane rockers worth it. Any gain in power from less friction?
RE: Thanks...
Thanks for the confusion....now that I recollect. It was a transition between ODB1 and ODB2. So I guess it is MAP or both. How would I go about supercharging it. Would I need a new chip for the MAP program?
Every GM car has a MAP sensor. Even if it also has a MAF sensor. Something is required to read vacuum.
Most cars from other companies also have a MAP sensor of some kind even if they are MAF equipped. Some do not have a MAP sensor but only a few.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
I agree with Cliff on the A-bodies. You can look at the pinouts/wiring diagrams on the site and see there is no MAP input into the PCM.-Brad-
