3.1 turbo
  • Jsmoove
    • May 2005
    • 2
    3.1 turbo
    hi i am new to this site and i need some advice have a 88 beretta wich is on its last legs due to my gf borowing it and somehow got a oil leak and then drov it for 2 days without oil . now i am puting in a 3.1 liter engine with mild cam and i also want to turbo it now i can do all the mechanical work myself but i know absolutly nothing about computers. so the queston is if i turbocharge the 3.1 will i have to get anything done to my computer any help would b great thnx
    p.s. i love the site
  • kflo 93 gt
    Bangin' Gears
    • Nov 2003
    • 238
    RE: 3.1 turbo
    You will need computer adustments of some sort no matter what, if you go the boost route. Give us a little more info, like what you're planning for a turbo set up and we can most assuredly help you out.
    14.60 @ 96.33 for now...
    • JamesonGT282
      • Jan 2005
      • 208
      The easiest thing to do is what I am doing, get a TGP or turbo grand prix memcal, it will plug right into your computer. If you are going to go turbo, you might want to skip the cam, it opens up a whole new bag of worms. if you do the cam, get a custom memcal fom someone like Darth Fiero who will tune specifically for your application.
      '91 Beretta GT 282 swap GONE
      '98 BMW M Roadster stage 2+ boosted
      '06 Saab 9-5 wagon 5mt tuned
      '11 Saab 9-3 XWD tuned
      • TurboZ24
        • 299
        The issue with just plugging in the TGP memcal is it actually doens't work 100% correctly. For some reason (which no one has answered too satisfaction), several functions do not work as well as they run horribly rich using the Cavalier ECM, the TGP memcal, and the TGP injectors.
        For example, a Cavalier ECM with stock TGP Memcal, you end up running around 9:1 fuel ratio after the converter, which of course is way too rich.
        Curtis
        91\' Turbo Z24
        http://www.turboz24.com
        • Jsmoove
          • May 2005
          • 2
          i was thinking of using the turbo off the ford tubo coupe for the beretta but if anyone els knows of a better turbo to use i would really apreciate the info as i am mechanicaly inclined but turbocharging is kinda new territory for me also im not sure if i should do the top end swap first and if i go to gen 3 heads i think i will need new pushrods does anyone know where to get them and the dimensions needed ..................................I really want to go fast but i dont want to mess with the ecm because when it comes to wiring and computers im not to sure what i am doing
          • TurboGTU
            • 453
            As far as computer wise..that would be NEW 22lbs injectors, 2bar map sensor, memcal and fuel pump from a 89-90 Turbo Grand Prix. The TGP intake air temp sensor would be nice too ..but it would have to be tapped on your intake manafold. You would still need it since your going to have to ditch your MAFF sensor.
            My beretta schematics and TGP schematics ALL fall on the same wiring I/Os. The TGP .727 and the Beretta 730 have the same "Layout" inside too...SAME I/O. SAME LOGIC. Wireing outside to the injectors, O2, and other sensors are the same. My beretta runs fine with the TGP MEMCAL. The only thing that doesn't work is fuel cut...due to prob the fuel pump relay beeing hotwired on my car..(previus owner). Dunno whats up with the "TGP" inspired CAVIs and stock ecms. would be nice to see the wiring and ecm service code to make sure.
            If you don't want to mess with things too much..then the Ford 2.3 turbo would be nice.
