For my 1997 Cutty, where can I find a heavier duty radiator? Working towards a 280HP goal, better cooling is needed. Thanks.
Better radiators
Griffin Thermal Products Radiator Manufacturer, Aluminum Radiator, Custom Radiators, Heavy Duty Rad, Performance, Off Road, Industrial, Muscle Car, Street Rod, Radiator
hi cfm fans
not sure if they have anything that is marketed for your car, but im sure if you talked to the guy and gave him your measurments hed have one that fits...
or you could call alocal rad shop and get a 3 core rad
I suppose, I hadn't even thought of just using dimensions to find one. Duh!
Thanks for that help.
Thanks for the link. I'll look in to it.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
Did you check to see if the '97 GTP's had a better radiator than your 3100? I'm not sure if different W-bodies shared the same rdiator shapes or not, but the GTP was 245HP stock, so the radiator should have enough cooling capacity to handle 280, and would be an easier fit than a custom aftermarket rad. You might also just wait until you get the engine built and see if you need the extra cooling capacity. No sense spending the extra money if it isn't necessary.
Marty'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
I hadn't even thought of that. Thanks for that idea, too. See, you guys always come up with something!\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
OK, talked to a radiator shop in the town where I work, and he came up with a 1-1/8" core unit, apparently from a '92 CS with a 3.4 DOHC. It, of course, isn't a factory unit, but would that even fit my '97? The stocker is a 5/8", he told me, to that's twice the thickness. Thanks.\"NASCAR is an integral part of my life. A part of me died when Dale Earnhardt died.\"
