3.1 preformance hint please...
  • 91corsy
    • Jul 2005
    • 6
    Hello,
    I own a 91 corsica, and I wanted to do a unexpensive mods. First off I want to put better manifolds, and i need to know what GMs carried the 3.4l that would fit my 3.1. Also I heard a rumor that the throttle body on the 2.8 might be a good swap to improve acceleration. Please advise, as i am fairly new to the 60 degree v6s
    Thanks
    91corsy
  • Berettaspeed
    • Apr 2004
    • 109
    well what is the price range to you that is"cheap"??? fast and cheap is not very easy. it can be done but its not easy.
    for under 1000 dollars im sure you can do a 3400 engine swap. this will give you alot faster of a car, and........a new engine!!! it will be like a new...old car you will nee dto take out that 3.1 totaly though. sometimes if you find a good price you could get away with around 700 dolars total. some people have gotten engines for as low as 300 dollars.
    otherwise a TB can be around 200 dollars. exhaust can be around 200.
    the best bang for your buck ...i would say is the 3400 engine swap. There is a ton of info on this swap.
    and others but i don't know for sure.
    89 BerettaGT 3400 5spd
    60' 2.106 street tires
    Best ET 14.313@95.37 N/A
    Now Boosted
    14s@109 (poor tune still rich, poor driving skills, poor owner)
    • 91corsy
      • Jul 2005
      • 6
      what about junk yard stuff?? throttle body upgrades, exhaust manifold swaps...inexpensive stuff from the local'Pull-A-Part' that would interchange fairly easy!
      • SHOoff
        • Jul 2005
        • 356
        Like he said. Go for the 3400 swap. If you have to, hunt through the junk yard and find an entire 3400. The swap that bad mofo in there. You'll not be disappointed.
        97 Cavalier RS
        3400, Isuzu MK7
        • Berettaspeed
          • Apr 2004
          • 109
          nothing comes to mind with finding 2.8/3.1 parts in a junk yard.
          doing manifold swaps you would have to get almost the whole engine and just the same amount of work as the 3400 swap...if not more. its very simple if you have some knowlege of cars and the basics on how thet are put together.
          you can get under drive pulleys around 100 bucks??? i don't know the exact price.
          Now Boosted
          • 91corsy
            • Jul 2005
            • 6
            I should also mention I have a MPFI, not a SFI, that shouldn't complicate with the swap right??
            • SHOoff
              • Jul 2005
              • 356
              No. That's how your computer is programmed. Basically if you swap to the 3400, you'll have a MPFI 3400. Cuz you're still gonna use your ECU and all the wiring for it.
              97 Cavalier RS
              3400, Isuzu MK7
              • 91corsy
                • Jul 2005
                • 6
                I thought the MPFI was the intake system, the SFI has only one injector (on the throttle body) and MPFI has an intake per cylinder... please RSVP, because i am a bit confused now
                • Doubt_Incarnate
                  I still watch ROBOTECH!
                  • Jan 2005
                  • 1130
                  MPFi has 6 injectors fired in sets, TBI has one or two on the throttle body and SFI has 6, but fired sequencialy as each cylinder needs.
                  • vsop4me3.1
                    • 482
                    well I'll probally explain this wrong but
                    MPFI multi port fuel injection pumps gas into the cylinders I think like four at a time while
                    SFI sequential fuel injection pumps individually as needed, but at the upper RPM sfi turns to MPFI
                    both have 1 fuel injector per cylinder (total 6)
                    how'd I do?
                    EDIT: damn I type too slow
                    I wish 10% of the people on the road knew how to drive
                    • 91corsy
                      • Jul 2005
                      • 6
                      ok that makes more sense.... so ur saying SFI is better than MPFI?
                      • WhiteRaider
                        • May 2005
                        • 133
                        SFI is slightly better than MPFI at lower speeds. The difference is nothing you would ever notice. At higher RPMs, the SFI can't keep up and reverts to MPFI anyway.
                        The MPFI computers control the SFI engines just fine and are widely hacked and widely available on the cheap in the junkyards. You probably have a 7730 ECU in that Corsica which is one of the preferred computers to use.
                        • SHOoff
                          • Jul 2005
                          • 356
                          Well.... SFI is better than MPFI. Better Idle, gas mileage..... crap like that.
                          But you're looking to modify your vehicle for more power, which suggests that you're probably going to use it to race something else. Which is going to probably put the engine into 3000+ rpm operation, or Power Enrichment mode, at the least. Either of which, will put it back to MPFI.
                          When running an SFI motor with your MPFI ECU, you just need your MPFI injector harness.
                          97 Cavalier RS
                          3400, Isuzu MK7
                          • Guest
                            For the most complete info on swaping a 3400 or building a hybrid for a J-body go to www.domesticcrew.com.
                            L-bodies are very similar.
                            We are also adding more info for other vehicles as well.
                            • 91corsy
                              • Jul 2005
                              • 6
                              Thanks!!
                              OK I think I got it all figured out, SFI (Sequential Fuel Injection) is MPFI (Multi Port Fuel Injection) at higher RPM, and SFI at lower RPM. Which makes better fuel economy.
