I need to know the spring rate on a LS2 valve spring. open and closed.
Spring rate of LS2 springs?
Tags: None
Thats not spring rate. Spring rate is a constant. You are looking for open and closed force.
Valve Spring Load - Closed 340 N at 45.75 mm (76 lb at 1.8 in)
Valve Spring Load - Open 980 N at 33.55 mm (220 lb at 1.32 in)
The maximum spring rate is 50.64N/mm which is a constant on a straight spring but is actually only the maximim on an LS2 spring bcause of its behiveshape.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Depends on installed height.'99 Z-28 - Weekend Driver
'84 X-11 - Time and Money Pit
Quote of the week:Originally posted by AaronThis is why I don't build crappy headers. I'm not sure, I don't know too much about welding.
