Another 3.1L to 3400 top end swap question
  • Chris88CL
    Moderator
    • 212
    Alright I've talked to people who have done the swap and I've gotten different stories. Are custom length pushrods needed or not?
    Its a 93 3.1L MPFI engine in a beretta, going to a 2000+ 3400 top end (heads and manifolds). If they arent needed that would be GREAT. Save me some measuring. If they are needed, does anyone know the specs so I can just order them?
  • Anonymous
    I believe (although I could be wrong) that the your 3.1 ones should work. I think its the same as the 3100, which has the same basic top end as the 3400. Get some other people's advice thou cause i don't know for sure.
    • GPXSS
      • 588
      If you are not modifying anything else, such as a performance cam, shaved heads, thinner head gasket etc.. then Yes, you can use your stock 3.1 pushrods.
      However, I would highly recommend you check preload after its all together to be sure.
      I modify stuff
      • BerettaMX
        • 17
        LoL you wont like this much but I compared all my pushrods 2.8, 3.1, 3100, 3400 and they are all not the right size. So you will need custom length pushrods. Unless you think you can get away with it, I would definately check.
        -=1989 2.8 Beretta=-
        3x00 Port&polished top end, Crane cam, NX EFI Kit, Manual conversion, 62mm TB, many more..
        13.34et@106mph 242whp 326wtrq
        --------------Sponsored by-----------------
        www.americanperformanceofcolorado.com
        • QuasarCorsica
          • Jan 2004
          • 1
          this is the same thing i want to do. i have a high lift cam in mine though, and i put the stock 3.1 pushrods in to check for clearance and the engine rolls over fine but im unsure what will happen when the lifters pump up. has anyone done this swap, i sure would like to know what would happen, i dont want to mess up my engine.
          thanks
          Zak
          Zak
          The Few, The Proud, The GM FWD.
          1990 Beretta GT
          1990 Beretta Base
          1993 Corsica LT <--Quasar!!
          • MasterJacko96
            • Jan 2004
            • 61
            If u have the old 3.1 like i think u do i dont think u can swap 3400 intake manifolds on without some major work but please correct me if i'm wrong
            1996 Monte Carlo LS 3100 engine, 1/4 16.131 *RIP
            88 cuttlass supreme 2.8L coupe
            90 dodge daytona 3.0 v6
            • v6h.o.
              • 1418
              the stock pushrods are just slightly too long.
              you'll need to check for proper lenth and order some custom pushrods. its really not at all hard to do.
              Colin
