Arp contact info? and quick question
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    Does arp have a website. i went to arp-stud.com and it doesn't work
    As for the Part #'s off this site
    8 - Undercut Long studs (11mm x 1.5 & 7/16" - 20) - ATP5.4LU
    8 - Undercut Short studs (11mm x 1.5 & 7/16" - 20) - ATP4.650LU
    16 - Hex Nuts (7/16" - 20) - APN58 or 12 point nuts (7/16" - 20) - APN12-1
    16 - Washers (7/16" ID 13/16 OD) - APW1316N
    Now in the bold there. I have the choice of either one? or do I get both? Since i see the "OR" in there. Or am i just simply confused.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
  • smilinguy99
    • 147
    Here, let me get my spoon...
    He who dies with the most toys is still dead.
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      so i have to call them to get the studs then huh.
      • TurboGTU
        • 453
        You mean the NUT. Well you wanna use a 6 point socket or a 12 point socket?.. Usually 12 point sockets have more to grab on to the nut while torquing. Yet..most impact sockets I have use a 6 point. Guess its more of if you like the look of a 6 point or 12 point. 12 point looks more high tech....I guess.
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          It used to be ARPracing.com. But looks like they are going for an update
          Oh and you have numbers for 7/16 studs. But unless its something other than a 660 that is not the right stud.
          • blackbombshell95
            Kaiō-ken X 10
            • Jun 2004
            • 1386
            its for a 02 3400
            • geoffinbc
              • 5831
              Uhh yea you had 7/16-20 nuts listed there. That sure isn't right if you using them on the 11mm studs.
              I made a mistake before you have the right studs but wrong nuts and washers.
              • RacerX11
                • 1060
                7/16" nuts are the correct ones to use with these studs.
                Marty
                '99 Z-28 - Weekend Driver
                '84 X-11 - Time and Money Pit
                Quote of the week:
                Originally posted by Aaron
                • geoffinbc
                  • 5831
                  Ahhh im blind. I see that have a 7/16 top
