3.1 L Turbo Set-up
  • Dean
    • Sep 2005
    • 11
    3.1 L Turbo Set-up
    Is there any documented information on the GP Turbo that was built in the middle 90s? I am curious to see what GM used as fars parts and routing. I wouldn't mind doing the same for my '96 3.1L GP.
    Would anyone have this info?
    Thanks!
  • Guest
    RE: 3.1 L Turbo Set-up
    It was '89 and '90, and there is info around, in these forums and W-body sites. I believe there's also info in teh family tree, and pushrod sections to the left.
    • Doward
      • Dec 2003
      • 127
      3.1L \'88 Camaro - 16G @ 9.5psi
      222/291 @ wheels
      T61 on the way!
      • tejohnson
        • 359
        Here is one bolted to a 3.1
        http://www.donkeypunchperformance.co...roducts_id=204
        But of course it is aftermarket...
        Regards,
        Todd E. Johnson
        • sharkey
          • Jun 2004
          • 2061
          the 3.1l turbo motor was built by mclearen in 89-90 and was in grand prix "TGP" cars. it was basicly a stock 3.1l motor (some will argue about some parts being treated and such, but the part numbers are identical to the na motor) but with a turbo. i beleive it was 205hp. it used a fiarly small t25 turbo
          • mfewtrail
            ~600hp worth of 3.1's
            • 170
            Here's a thread from the W-body board that outlines some of the differences between the Vin T & Vin V engines.
            EDIT: As far as "routing" goes, this is how they look stock(I have a cone filter placed on the stock turbocharger instead of the stock airbox/ducting that would be running across the front of the engine/under the dogbone engine mounts up front there).
            I can probably dig up some pictures of the turbo 3.1 out of my service manual that show how everything is placed/routed as well(I'll post them if/when I find them).
            Matt F.
            TGP 1/4 mile times
            http://photobucket.com/albums/y33/mfewtrail/
            1990 TGP Coupe VIN Database
