Wanting info on mods for 1988 2.8
  • jeff_falk2005
    • Oct 2005
    • 3
    I have a 1990 beretta GX with a 88 gt 2.8 engine. 67,000 miles and am looking hard to find some performance mods, info on porting plenum and intake...maybe custom cold air. would it be at least more than likely i could get good results out of placing a turbocharger in it or is it going to ruin my engine? what could i do to max the performance out on this engine staying under 3 grand in mods?
  • Gangstgprix.
    • Oct 2005
    • 7
    There is a turbo kit for sale on the W-body forum right now .on E-bay actually, for $500. not sure if the link is somewhere here?
    Looks like it is a T-25 turbo like a garrett but made in France.
    go over to TGP forums when you get it, will get you what you need to know.
    I can probly get the actual link if you want.
    1990 Turbo Mclaren Pontiac Grand Prix.
    http://www.cardomain.com/ride/2056262
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      Do a 3400 swap you will be far happier and will also be running in the 14's or very low 15 depending if it is auto or stick.
      You get all the modern perks of the new engine.
      • sil
        4T60-E killa
        • Nov 2004
        • 723
        ya, id go with the 3400, get a regrind on the cam
        you will have alot more piston/valve clearance than a 2.8 block
        been there (doing it) lol wish i had a 3.1 block i did up, i had to get my pistons machined for the clearance on the valves, and im running a 469 lift
        port the 3400 heads they have the larger 1.76'' diameter intake valve
        and gasket match the 3400 head/lower/upper intake manifolds
        the 3400 will yeild more compression than the 2.8/3x00 combo
        get the turbo and replace the computer and run the tgp code
        5 spd getrag 282 / 284
        and the rest is up to your imagination i guess
        • jeff_falk2005
          • Oct 2005
          • 3
          stock 3400 in '90 beretta
          if i can just swap to a 3400 and get better results than a 2.8 or 3.1 stock than im happy with that if its easier than to upgrade the 2.8 i have in it now. will the 3400 mount to my current tranny which is stock off the original 3.1? what am i going to need to just drop the 3400 in and run it like it is, new mounts etc? can i use the same cpu? what electricals am i going to have to change? should i brace the front end more since it will be a bigger engine?
          • sil
            4T60-E killa
            • Nov 2004
            • 723
            this guide should shoot you in the right direction
            http://www.domesticcrew.com/installguide.htm
            i would also suggest some tuning to your computer
            unless you grab the computer from the donor car
            but then youll have to re wire a little and not sure if your cluster panel is compatable, some cars have the sensors feed direct to the gagues, some are through the computer
            its alot more work changing computers, much easier to jsut tune what you have in there right now
            you can visit www.gmpcm.com for the program.. i use gmpcm and like it alot, all there deffinition files are complet emappings
            you just have to figure out what computer you have in your car and then figure out the deffinition file to use with gmpcm
            gmpcm is a good place to ask tuning related questions(mick is a genious) lol
            you will also want to be able to "log data" this is what you do to see what areas you need to adjust in your computer
            you can get cables from mastach mastach.com
            visit http://www.moates.net/, they have the willems eprom burner, chips, adaptors and all sorts of funky stuff to check out
            • jeff_falk2005
              • Oct 2005
              • 3
              trans question
              ok i got that. will my original 3.1 trans bolt right up to the 3400 without mods? and if so is there a way i can gear it lower than it is by modding the orginal trans or should i get another one that will go on the 3400 that already is geared lower?
                • 9191
                RE: trans question
                Yes, it will bolt up.
                Yes, you can change the gearing. Look either in the tranny section of the site or of the forums for discussions and how-to's on this.
                • Ortie666
                  • Jul 2005
                  • 340
                  WOW, under 3 grand?? man.. u could upfrade the crank to a 3.1, and rebuild the whole thing wile putting a cam in and whatnot and ya, bore it.. molly ring it.. and ur gunna be good ta go,
                  Six-t-Six Motorsports
                  2.8L Chevette Roadcar
                  3.2L Acadian Racecar
                  • geoffinbc
                    • 5831
                    A 3.1L with stock heads and intake will not touch a 3400. Even with a new cam. Moly rigs wont do shit for power. They require a apecial cylinder wall finish which is costly aswell. You can only do a cleanup bore on a 3.1L.
