Tired of looking, need rocker order for adjusting valve lash
  • Jerriko34
    • Nov 2004
    • 9
    I know that you adjust half of the valves at TDC and then the other half at 180 degrees. I need to know which ones at TDC and 180 degrees.
    Thanks in advance,
    Jim
  • sharkey
    • Jun 2004
    • 2061
    RE: Tired of looking, need rocker order for adjusting valve
    thats never the way i adjust valves in anything. here is what i go by
    work on one cylender at a time. turn the motor over so the exaust valve is just starting to open (pushrod is just moving up) and set the lash on the intake valve. turn the motor over till the intake valve is just starting to close (pushrod moving down) and set the lash on the exaust valve
    ive used this method on everything from a 1.6l toyota all the way to a 3500hp alcohol dragster.
    • v6h.o.
      • 1418
      ADJUSTMENT PROCEDURE FOR V6 ENGINES:
      With number one piston on the firing position at TDC install the rockers on the studs, the valves that can be adjusted are:
      EXHAUST: 1, 2, 3
      INTAKE: 1, 5, 6
      Tighten in the adjusting nuts until all lash is removed. This can be determined by rotating the pushrod while turning in the adjusting nut. Once the play has been removed, turn in the adjusting nut one-half turn to center the lifter plunger. Now crank the engine over one complete revolution to number four firing position. These valves can now be adjusted:
      EXHAUST: 4, 5, 6
      INTAKE: 2, 3, 4
      Colin
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        One half turn is not enough preload for a stud with a 1.0mm thread pitch. At least 1 turn should be added. The manual says 1.5 but some claim that is too much.
        • StudlyCamaro
          • Nov 2003
          • 692
          my information suggests a 3/4 turn... so we now have 3 different options
          jim are you back in the 60* game?
          3.4L camaro some goodies
          • lilredneon
            • Oct 2005
            • 1
            Hes been helping me with my Beretta, and is thinking about another V6
            95 Dodge Neon on the juice
            87 Mazda B2000, 57ooo miles, needs juice
            94 Beretta 3100
            • geoffinbc
              • 5831
              Is that on stock studs? My FACTORY service manual (stolen from my dads dealership when they switched everything to compuer) says 1.5 tuns. So thats that.
              • Jerriko34
                • Nov 2004
                • 9
                Re: RE: Tired of looking, need rocker order for adjusting va
                EXHAUST: 1, 2, 3
                INTAKE: 1, 5, 6
                EXHAUST: 4, 5, 6
                INTAKE: 2, 3, 4
                Thank you, that's exactly what I was looking for. I knew that was out there somewhere.
                Studly, it's a possibility. I have sooo much stuff here to do it.
                • StudlyCamaro
                  • Nov 2003
                  • 692
                  that came from my haynes service manual for 93-2000 F-bodies in the 3.4L section
                  score
