Aftermarket lifters
  • ikessky
    • 614
    Aftermarket lifters
    Are there any aftermarket lifters available for the 3x00's? Maybe something stronger, maybe something lighter, etc. Maybe I'm just shooting in the dark....
  • project60degree
    • May 2005
    • 85
    There are some aftermarket lifters on summitracing.com made by speedpro
    p/n SLP-HT-2270
    • ikessky
      • 614
      Hmmmm..... Summit does a real good job describing those. I'll have to do a little more searching for info about them (weight/performance).
      Thanks for the start though.
      • project60degree
        • May 2005
        • 85
        those are the only after market ones i have found so far. I think u can use that p/n on jegs.com but i think there a little more there. keep use posted on any info if you could thanx
        • ikessky
          • 614
          Nothing comes up at Jegs. I e-mailed Summit tech support, so hopefully I'll get an answer soon.
          • geoffinbc
            Iron Head Enthusiast
            • 5831
            Go to speedpro's website
            • ikessky
              • 614
              Wow. Do you think this is my first time using the internet? I'm not trying to be a prick, but I usually search a manufacturer's website before I ask a technical question like this. http://www.federal-mogul.com/cda/con...5_6939,00.html There search function doesn't give me anything results and their parts spec. catalog brings me to a "Page Not Found" when I go to technical highlights.
              • geoffinbc
                • 5831
                Well you never said you checked Speed-Pro and it failed. All you said was summit and jegs... So I asumed you never looked.
                • ikessky
                  • 614
                  Ah, I see. I guess I should have stated that originally. Maybe I'll just call Speed-Pro's tech people and see if they can tell me.
