wow looking good!
Can anyone guess?
14.96@91.47 in the 1/4
9.63@74.36 in the 1/8th
yeah i was going to hide everything under the plenum originally, but there is no room for the piping.Originally posted by blackbombshell95is their a reason why people just don't drill holes in the plenum?
this way its also easier to change jet sizes. i suppose you could put them right on the UIM but if i ever wanted to get rid of the unit it would be an easy bolt in for anyone else with large port runners, with only things needed being 60mm bolts and another gasket.
more then that though, i didnt like the angle that the nozzles would have had to sit, to get the right spray angle, if they were in the uim.got zap-straps?
89 Z24
13.886 @ 96.16 mph
street trim - slicks
those parts polished or chromed? pretty!!!!Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
if you havent got the holes aligned or some1 wants a one off set, if you have a big enight scanner you could scan the upper plenum on the scanner to get exact measurments. just a thought, those are sweet thought man i wouldn't mind a set, nice job!!
They were designed from a CMM of the actual lower manifold, so they will be alot more accurate than trying to go from a scanner.-Brad-
