feul injectors
  • hac_gagt
    • Oct 2005
    • 19
    feul injectors
    My fuel injectors need to be replaced so I figured I should upgrade them. I have a mostly stock car so what fuel rating should I go with? Also when adding these should I add an adj. fuel pressure regulator?
  • ProjectMM
    • Mar 2004
    • 170
    RE: feul injectors
    year, make and model would be a good thing. and the motor! also
    2002 Pontiac GrandAm GT1
    3400 v6
    TOG headers
    RSM 62MM T-body
    FFP underdrive pulley
    GRANATELLI MAF
    Ported upper intake
    MSD DIS 4 ignition box
    MSD Wires and coils (pending)
    Venom high flow fuel pump (pending)
    • sharkey
      • Jun 2004
      • 2061
      RE: feul injectors
      get stock replacments. if you dont have any serious mods and cant tune the pcm, you are just gonna waste fuel and drown your motor out.
      • Manitcor
        • 573
        RE: feul injectors
        werd, if anything get some injectors cheap from a J/Y that are stock replacement and send them off to witchhunter to have them cleaned and flowtested. Most injectiors dont just go bad, they just need to be serviced.
        Cleaning and flowmatching 6 - 660 injectors is about $80
        1995 Monte Carlo LS
        3400 SFI 60v6
        • SHOoff
          • Jul 2005
          • 356
          Re: RE: feul injectors
          If i'm correct on this.... that's probably much less than you can buy the 6 of them new.
          97 Cavalier RS
          3400, Isuzu MK7
            • 9190
            RE: Re: RE: feul injectors
            New injectors are between $40-60 each.
            • AaronGTR
              boost lover
              • Jan 2004
              • 708
              Yeah, no need to upgrade injectors or get an adjustable regulator on a mostly stock car. You need some pretty serious mods and the ability to tune the computer before you do that.
              '97 Grand Prix GT 3800 (sold)
              Gotta love boost!
